lol got banned on the 29th, so much for the release discussion, so frustrating
anyway performance of the 480 was ok as expected, price also, personally didnt expect much of the cooler, and i was right
but super disapointed at the efficiency, and overclocking headroom.
i was hoping AMD wouldn't make this error, but they went ahead and made it, it's just really dumb, i think performance was sub 970, and watching all the hype AMD pushed the clock higher, they really shoudn't have done it.
160-170watt power draw ?? its supposed to be 120-130 watt, and i think the pci-e draw will be solved in the bios, this is probably a mistake made during last clock push, someone confused the setting for the 12vrail with pci-e draw limit.
but the thing i cannot understand is the amount of power the card needs, even if they made custom PCB for AIB, with better thermal and power delivery, raising the OC headroom, what would the card need for 1500-1600mhz 300watt? what card uses 30% more power for like 5% overclock ?
this is insane, need to see the 470 and it's efficiency compared to the 480, to establish if this is a chip issue or a inadequate clock issue.
