It is 8 pin
Why do people love the G1s so much? What's different about them? More copper?
970's the g1 has a better 4 pipe heatsink and a more aggressive boost bios and back plate.
The wf3 model has a 2 pipe heatsink no backplate and less aggressive boost bios.
Gigabyte tend to lock the voltage controller on amds.
Is there likely to be much of a difference in performance between the various vendors or is this more of an aesthetic choice?
No.this is against a 970 @ 1550Mhz, 30% faster, 10 to 15% faster than a stock 980, a stock 980TI is a good 25% faster than a stock 980.
So the RX 480 @ 1350Mhz is about 15% short of a stock 980TI, it would have to clock to at least 1550Mhz to match a stock 980TI, probably more cuz scaling, if those fabled AIB 1.6Ghz RX 480 actually materialise they might just do it in this game and possibly other DX12 games, Hit Man is probably the one game where it may stomp all over the 980TI as the 390X already beats it and at 1.6Ghz the 480 waaaaaay faster.
But, and i say again through fear of the Gibbo, the 980TI overclocks too, like a trooper.
Are you having a little trouble with the maths there?
You're saying that overclock puts the 970 at 10-15% faster than a stock 980, and you're saying a 980ti is about 25% faster than a 980, which means that 970 is only 10% or so slower than a 980ti at stock.
Now the RX480 is 30% faster than the overclocked 970........ that would put it way beyond the 980ti by your numbers, which I have no idea if they are correct.
^ According to these taken over a large spread of games.
The 980Ti is 40% quicker stock for stock here
http://www.pcgamer.com/radeon-rx-480-review/
and ~33% faster stock for stock here
https://www.techpowerup.com/reviews/AMD/RX_480/24.html
Obviously the 980Ti clocks like a monster and the rx480 does not so i can only see that gap widening a fair bit when both are overclocked.
Compared to the 970, the Rx480 seems to be 5-10% quicker according to that spread of game averages ^
no one buys a 980ti today, they are way better off buying a 1070.
How do you know though? Do you know what AIB 480 cards overclock like?
No i am basing that on all the information we have so far which is that the RX480 has a HUGE way to go to get the same overclocking capability as the 980Ti (in terms of a percentage overclock over stock).
We've only seen 1500mhz and that was on an extensively modified water cooled RX480 with the power limit set at 300%!.
Yes the AIB cards may have more power connectors but we saw how well that helped on the 1070 and 1080 didn't we...![]()
With all the modifications the guy failed to bother cooling the memory or VRMs, or any other chips that needed cooling(I haven't seen if there are 1-2 other chips that need cooling, there often are).
so what? Do you think that would have made big difference to what they would get on the core?
Do you realistically see ~1600mhz clocks being commonplace on air on these?
