No this is the same mistake panos made, and remained quiet and pretended to let it go un-noticed. It's not a rebadged instinct card.
V7 has it's own pcb, different voltage regulation and had to put back on the display I/o.
Aswell as the pcb design cooler and shroud.
Panos was trying claim they are all the same card, and it would be a $50 loss .
https://forums.overclockers.co.uk/posts/32458007/
16GB HBM alone cost $320 for AMD to buy. That's almost half the price of the card.
https://www.fudzilla.com/news/graphics/48020-radeon-vii-production-cost-650
And in the future when you want someone to reply, please quote their with @ in front
On you reply your other post. The package is tested. HBM+GPU+Interposer.
If some of it cannot go to MI60/MI50 due to error, AMD has something to do with it or throw it into the bin. As it cannot remove the parts and re-purpose them. Especially the expensive HBM.
Add also the $150 worth of games attached to it, which lets say AMD buys for $50 in total all 3, you will see that they might break even at $699 over BOM. Let alone marketing etc costs on top.
