Rate my pothole repair...
Re: "how much we pay them". Most councils have now been through years and years of cuts. Sorry, I mean "efficiency savings". Ours has had to balance the books with cuts in the tens of millions, every year, for years.
Funnily enough, services have suffered across the board. Who'd have thunk it?
At least they've filled them in for the next few weeks...
I popped out to the local Screwfix earlier and was practically playing dodge the potholes, as the council marked the worst of them about 2-3 weeks ago but haven't done anything to them.
One is currently large enough you could probably drop a mini tyre in it, as in from the car, and it'd probably just about fill it.. (if you hit it, I suspect you're going to be lucky to get away with just a damaged wheel).
The really annoying thing with these sorts of patches is that they usually only last a few months before you end up with an even bigger hole.
Historically, ours was pretty good. In recent years, they have to get to the point of being able to fit a small child inside, before anything gets done (poorly).
But given how much funding has been cut, I can't say I blame them.
Some of the potholes around here are big enough for my motorbike wheel to drop into and you'd either go over the handle bars or crack your rim. I've reported them a few times but they're still there months later and getting bigger
I'll bet the money spent on that could have produced a better job. Nobody gives a **** any more.
Private hill so we have to repair our own road (no pavements), I've gone through a fair amount of wishbones and drop links over the years. same with pipes and sewerage
Time to privatise road mantainence, innit. I'm sure the private sector will do a much better job, much more cheaply.
/s
Apparently the council got these experts to do it:
Cute are made at the bottom end of the scale never at the top where it would make a huge difference.
Around here they filled in one pot hole and yet left the slightly shallower one right next door to it. Also didn't seal around the edge so it will lift quickly.
