Rate My System!
Dirtysanchez said:
This is a very basic question but.... Is it easy to build this PC without basically any experience and get it all working fine??
Read all manuals and a basic guide, and you'll be fine.
Theres enough collective experience on here to fix almost anything. Anything you are unsure of or need help with, start a thread and someone is bound to know.
Just make sure if you don't know what your doing, ask to be taken through it rather than having a go and breaking something.
Raikiri said:
Can you check your PSU, it is running crossfire so it can't be THAT bad. Check the make/model and see how many amps it has on the 12v rail(s).
Hard drives, not great but worth keeping.
Heatsink - Scythe Ninja is great, freezer 7 pro etc.
RAM - Check with CPU-Z to see what type and kind it is, if it is 667mhz then you could keep it and use the money saved to buy a 6400/6600 instead.
Graphics - The GTs are good cards, I would keep them but buy Zalman VF900 coolers for them
Case - Obviously depends on what you like, but something from Lian Li/Silverstone would be a good choice.
Lian Li are boring looking though
no_1_dave said:
Akasa Eclipse :D
Best air cooling case around. Get a couple of 120mm fans & away you go :)
Better than the P180? Thats my recomendation, although i've yet to own one. I agree that Lian-Lis are rather dull.
If your not serious about overclocking I would recommend this build, its similar to what I am getting except I am getting a full system
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£197.99 £197.99
HD-046-WD Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD)
£44.99 £44.99
GX-112-SP Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP)
£184.99 £184.99
MB-003-AK Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK)
£53.99 £53.99
MY-017-GS G.Skill 2GB DDR2 PK PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400CL4D-2GBPK) (MY-017-GS)
£124.99 £124.99
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£66.99 £66.99
Subtotal £673.94
VAT £117.94
Total £791.88
hmm thats the only thing i dont like about the setup, I dont know how good they are but im pretty sure i wouldnt trust a power supply that came with a case, would much rather a decent Seasonic even if the latest batch are a bit iffy, i trust em ;)
Antec are an exception to that rule, their psus are on the same level as other reputable brands like seasonic and that includes the ones they bundle with their cases.
