Realtek HD audio not working
Yes when I install chipset even monitor won’t go sleep now,
I should have clarified earlier - is this a brand new build?
Complete spec?
Reboot/ed?..
Did you clear the CMOS after updating the BIOS (a bit old school) - and reapply/check settings?
Complete spec?
Reboot/ed?..
No no this is well established build, been running fine for at least year until early on today, never had any problems, audio stoped working and I can only think that windows made some update, after that been trying to sort out with 2 fresh windows install, double checked bios and everything looks fine there, on latest bios, is fairly simple board that H310 so you can’t change much, only thing I done now is removed battery from board and trying to reinstall windows again with out any other sata connection, I’m sure it won’t make any difference but worth a try, I think is the board it self but just don’t know what happened
