- 16 Aug 2009
From what I can tell in the frantic research I’ve been doing about coil whine in the past 5 hours, is my PSU is definitely capable of running my 3080, coil whine doesn’t exactly mean my PSU is struggling, it’s just a response to the higher current flowing through it. Maybe I got a bit unlucky as like with all computer hardware, every component is different, even if it’s the same.
Coil whine is one of those irritating things that seems to happen at times it doesn't necessarily mean its struggling theres some kind of resonance between card and psu I had a GTX 1080 that howled like banshee whenever TW3 booted up did it occasionally with other titles but that was the worst. Then one day it simply stopped. It'll occur on most cards if you don't cap the FPS in my experience i.e. many hundreds of frames per second, its not new either there was a long thread here dedicated to whine on the GTX 970 that seemed to be common. Trying a different psu is the alternative different resonance etc.
