5w20 is the correct grade for the 1.0 EcoboostNot 100% sure what weight oil a 1.0 Ecoboost uses but if its heavier than it should be, combined with the very low temps, I could possibly see that the oil pump would have some trouble from cold. But then OP said the light came on while he was driving and close to home.
We had -9 here, so much colder than usual5w20 is what they use. But to be honest even if it was 20w50 on a freezing cold morning it should be more than capable of sucking that oil up and making pressure.
Modern Synthetic oils are good in terms of protection to at least -20CWe had -9 here, so much colder than usual
So...garage say it had the wrong oil in, which they've sorted and they've checked the belt and driven it around and no more oil light. The Bill is £250....why do I feel like it'll come on as soon as I pick it up
You’ve been tucked up mate I wouldn’t trust their opinion at all. You’ll always have these doubts in the back of your mind, waiting for engine to inevitably go boom.Think my only option is to pay up the 250, double check that he had checked the wet belt and go from there.
The number is the weight/viscosity though.The "W" in oil viscosity stands for "Winter", not "Weight".
How does he know the wrong oil has been put in though? Without sending it away for analysis it’ll be almost impossible for him to know this. It’s a guess at best.The number is the weight/viscosity though.
No idea which is why this was my response.How does he know the wrong oil has been put in though? Without sending it away for analysis it’ll be almost impossible for him to know this. It’s a guess at best.
Sounds like they're winging it and it's made enough of a difference to keep it off for a little bit.
They clearly haven’t got a clue what they are doing in regards to these engines. No one worth their salt would’ve told someone with that engine and those symptoms to drive the car there. That’s the first red flag. Then they try to tell him it’s had the wrong oil put in it, with absolutely no way of being able to prove it.No idea which is why this was my response.
