The Tannoy's are a no brainer at that price, assuming the sound is to your taste. Or get the Zu'sI used to have a pair of Druids and they were great sounding and beautiful looking but a bit ungainly size wise.
Got the Tannoys delivered today. Can’t quite make up my mind on them. They’re a little taller than my wife would like but is happy to put up with them (this is before I add an inch or so for spikes)
My main issue is they really feel like they’re missing something. No sure if it’s because they’re brand new and need running in but they sound a bit muddied when there’s a lot going on. Particularly the greatest showman opener which my wife put on almost instantly. Any chance you could see if you get the same?
Maybe it’s because the other speakers I’ve demoed have been at a higher end (though I believe these retailed around £1000 initially) but it certainly feels like a step down.
Going to have a play with placement over the next few days then make a decision I think.
This thread (or what I read of it) cracked me up.
Bass from TV speakers (what bass!?!) travelling up the wall, so buys speakers with more bass to solve the problem.
Mind baffled.
Winner. Looks like Pro-Ject do a Bluetooth turntable which is cheaper than the Yamaha. They also do a Bluetooth phono stage which i could use with my existing turntable which would save me a few hundred (and explain why a new turntable had appeared)
I've got a BK XXLS400 subwoofer and applied some Sorbothane hemispheres to the bottom as these are supposed to decouple the sub, not sure if the neighbor still gets loads of bass from it,
I'm aware the TV unit is off centre in this pic. It's since been fixed!
Wait till you try some higher end subs with more powerful amp and 4"+ excursion
