ElRazur said:
You mentioed that medical specialist says it is difficult to get rid of from medical instrument right? Can you show me the link please, i think you are mistaking a DIFFERENT STRAIN with Bacillus cereus. Different strains have different characteristics and attributes.
I never argued blindly, it is down to the fact im so infamous in here that whatever i say is deemed rubbish and im labelled arrogant
Perhaps people should see where my point of arguement is all along - the spore can be destroyed via cooking and microwaving hence making it safe for consumption
If you didn't actually read the articles, I do not really believe that posting the same ones that state that will be of any benefit.
The point is that the bacteria will be destroyed by these temperatures.
However; as some of them will not be destroyed due to extreme heat resistance.
Therefore there can be a problem.
The issue you seem to have difficulty grasping is that not all bacteria of this strain will be destroyed by these temperatures.
Whilst is is known that certain temperatures will kill bacteria, it is needless to clarify every single article printed with "of course, some more resistant ones will survive", as this is a given fact.
Once you can ackowledge this, you will be in a position where you can perhaps see that surviving bacteria - and these bacteria can indeed sometimes not die at temperatures that will usually kill them - can be a problem.
You need to bear in mind that even a single bacterium that survived out of millions, over 12 hours at room temperature, can have bred millions again.
And there you have the toxin buildup.
It is quite frighteningly simple to grasp, and for someone professing to have some degree of intelligence, it frightens me a little that you are unprepared to accept anything which contradicts your somewhat limited understanding of biology, bacteria, strains, and resistance.
If indeed you are studying biology you should be aware of this.
Admittedly I am a little rusty as it has been a decade for me, but I still maintain my faculties.
From a scientific viewpoint you must look at all data objectively, work through the available information, then from all available data follow it to itss logical conclusion.
In this case it is as follows.
This bacteriums will be destroyed by temperatures of 100 degrees.
There is a high probability that some will survive this due to adaptation in regards to heat resistance.
Bacteria can breed really fast at room temperature.
This bacterium can leave toxins that are not destroyed by re-heating, no matter what the temperature.
Ergo we can decide that there is a possibility of food poisoning from re-heating food that has been left to cool at room temperature.
