WS_TailGunner said:its entirely possible that people from exeter are just retarded i suppose.
Being a southern shandy drinker is it in fact anyone North of Watford who is retarded
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
Vanilla said:Being a southern shandy drinker is it in fact anyone North of Watford who is retarded![]()
The demarcation line is traditionally the Watford Gap.Vanilla said:Being a southern shandy drinker is it in fact anyone North of Watford who is retarded![]()
Dude, you seriously need to get out more. Just because the majority of people on this forum are aware of it doesn't translate to the wider demographic out there. It is fairly specialised after all. Just because you haven't heard about a problem means only that you aren't aware of it, not that it doesn't exist.Vanilla said:I don't doubt that it had happened at some point, but did it ever get to the stage where entire ideas were backshelved because of this threat that i've never heard being a problem? In this day and age everyone is well aware of who is around them and how to cover their pin.
Wrong. The chip readers aren't that difficult to reverse engineer and get round the technology that way. Also "bugs" which intercept the information as it travels down the wires inside the terminal have been found in petrol pumps, supermarket tills, etc, which is another way to clone cards. Besides which, the information about the PIN is encoded into the chip, so all that happens is that you write your own PIN into the chip, then use that. And look how many shops have security cameras pointing at the till, which is where the C&P terminal is.Vanilla said:The latest craze was to clone the card as it was put into an ATM and get the pin via a camera. No contact with the person involved, no violence.
This cloning is not possible in a shop and the card only goes into a standard reader up to the chip and a camera would have to be placed in the shop ceiling. Then they would have to mug or pick pocket the person.
It's already happened at least once that I know of, where an elderly lady was burgled shortly after coming home from shopping. Her card was taken and used - with the PIN - to buy a load of stuff that she wouldn't buy. She had used her card in a crowded supermarket and believes that someone watched her enter the number and then burgled her home to commit this.Vanilla said:Flawless? No....but I feel the whole 'see your pin and mug you' brigade is pure scaremongering, making a greek tragedy out of something that isn't a widespread or common problem.
Treefrog said:Wrong. The chip readers aren't that difficult to reverse engineer and get round the technology that way. Also "bugs" which intercept the information as it travels down the wires inside the terminal have been found in petrol pumps, supermarket tills, etc, which is another way to clone cards. Besides which, the information about the PIN is encoded into the chip, so all that happens is that you write your own PIN into the chip, then use that. And look how many shops have security cameras pointing at the till, which is where the C&P terminal is.
I'm not sure what you mean there Visage, by one-way hash. Encryption?Visage said:Surely the PIN itself isn't recorded, but a one-way hash of the PIN, making your arguments void?
Treefrog said:I'm not sure what you mean there Visage, by one-way hash. Encryption?
http://www.google.co.uk/search?hs=0...:en-US:official&q=chip+spin&btnG=Search&meta=
3rd result (.pdf) has some useful info on the strengths and weaknesses of this system.
Lagz said:Hmm fingerprint detection isn't reliable enough to work on a large scale. You inevitable get false matches etc. It is also not too hard to fake someone elses fingerprint if you obtain a sample from something they have touched. I'm not sure why they are bothering really?
MJ said:I had an idea a whilst back before chip and pin was really in action which would have been cool considering most big stores have big touch screen tills or at least tills which run of some sort of OS.
Instead of the actual cashier having any involvement with checking your signature you sign a touch sensitive signature strip on a little touch screen. (like you do sometimes when you sign for packages sometimes) but instead of there being a signature on the back of the card all signatures are stored on servers at the banks, so the computers check the signature not the cashier.
There used to be so many times I would sign for something and they wouldn't even check![]()
Snow-Munki said:heard on bbc this morning you can even use play doh to 'fake' someones fingerprint.
Other ways, you can blow on the scanner which brings up the prvious person's scan !![]()
Visage said:And if the comms link went down?
Or if for some reason the computer at the far end didnt recognise your signature? There's no manual fallback.
MJ said:That could happen to signing or pin the bank still need to authorise the card.
Edit:
then you should make sure its perfect mine is almost always the same.
Treefrog said:Dude, you seriously need to get out more. Just because the majority of people on this forum are aware of it doesn't translate to the wider demographic out there. It is fairly specialised after all. Just because you haven't heard about a problem means only that you aren't aware of it, not that it doesn't exist.
Related BBC story
It may not be widespread yet, but as it's the weakest link in the chain of security, it's the easiest to compromise. No hi-tech equipment to read and clone cards needed, just the willingness to mug or burgle. And we already know how common that is
DanSolo said:My point is in shops where the till display is not active or obscured there is no way of checking the amount before you put the pin in. Now i double check my reciepts after ive put my pin in, although imo it was much easier to see the amount on the reciept and then sign for it, oh well....
Visage said:There's a hash of the PIN on the magnetic strip for verification.
