- 18 Sep 2020
Gigabyte is also using better capacitors which may mean it negates this issue for some reason, the gigabyte is using 470 and the zotac is 330.
Also gigabyte might have tuned there OC better than other AIB's so it doesn't really hit the dreaded 2Ghz.
I have a 3090 eagle OC arriving next week and i feel pretty okay with it, but time will tell!
I saw that too, 470uF will offer quite a bit more filtering than 330uF. Not sure how it would compare to a bank of MLLC's at 2GHz+ but perhaps this was Gigabytes solution to the problem instead of going to MLLC's like ASUS/EVGA.
My Palit has 1 bank of the smaller "more expensive" caps and it has not crashed yet.
To be fair though, the highest I have seen it boost is 1980, I might try a small OC or place an intake fan under it to see if it crashes above 2,000
If your hitting 1980 MHz and getting performance better than the FE then I'd be happy enough with that.
