Are they cheaper than MLCC? Answer yes. So they are cheaping out..They are NOT cheaper capacitors ffs...
https://www.reddit.com/r/nvidia/com...reason_for_crashes_and_instabilities/g6k2dl6/
Sorry there is no defending this at all, this is a design issue, it should never have been allowed to happen.
Its a rushed botched launch from Nvidia and their partners.
You simply cannot defend this, if cards are failing at their advertised spec because the hardware setup is incorrect on the PCB, you cannot defend it by saying its fine, run it underclocked.
Take your nvidia shaded glasses off and head out of the sand
I think everyone should cancel their order, especially the Gigabyte onesI must say that my Zotac order is mm away from getting cancelled at this point
I got my Gigabyte 3080 gaming yesterday and havnt had any crashes yet while playing with it. Just heard about this issue and seems this card has the worst setup of capacitors so hoping it doesnt cause issues. Will keep testing over the next few days to see if anything happens but so far so good.
Its pretty quiet considering the last windforce cooler i had was super loud, tops out around 67 degrees at 75% fan in my setup. Will push the OC a bit and see if it induces any crashes like mentioned.
but they are hitting the advertised spec. Nobody is selling a card which they say boosts to 2000mhz so if they ship the cards out underclocked to avoid the crashing issue then that’s fine.
I have the same card and so far haven't had any issues but am going to play around with OC later today. Just need an official response from Gigabyte now.
If I was waiting for my card right now I would cancel and get my money back. Teach these greedy companies a lesson.
Anyone defending this debacle needs their head examined.
https://twitter.com/HardwareUnboxed/status/1309659834468298753The Asus TUF no OC is t affected by this issue right?
Here's some testing of the GigaByte Gaming OC I found
https://youtu.be/UrNIO0J7MKw
