On a positive note, this could mean that more people cancel their preorders on the cards with only 1 MSCC. When I receive it and I see crashes and instability with actual empirical evidence on the source of the issue I can either return it or RMA it if need be. Win-win.Not all SPCAPs are equal. EVGA may well have found issues with the caps they were using, doesn't mean the other manufacturers had the same problem. Besides which, are we supposed to take a large corporation at their word? I mean think of the incredible spin potential. Cards delayed and customers angry -> Tell customers that actually you're behind because you're improving the quality unlike those other guys -> Customers love that you did this and are now happy to wait and also consider your product to be better than competition.
Not one EVGA shipped with the all SPCAP solution allegedly so if that's true there'll be no issues on those cards then right? Let's wait and see on that.
Hardware reviewers get pre production samples, with incomplete drivers/bios etc. They expect crashing, but they also know that it's not likely to be an issue in consumer cards and are usually told "we know these have some issues but they will be fixed before launch" and they go along with this. Whether this is morally right or not doesn't matter but that's why they come out after the fact saying x product crashed in testing for us and we didn't report it at the time of review.
Hardware unboxed have stated that the have had the crashing issue on an Asus TUF which features 0 SPCAPs. So no one can point at the caps and say it's definitely them.
Only if you consider your time to be free. Alternatively you could wait for the vendor to fix their faulty product.On a positive note, this could mean that more people cancel their preorders on the cards with only 1 MSCC. When I receive it and I see crashes and instability with actual empirical evidence on the source of the issue I can either return it or RMA it if need be. Win-win.
Here is another post which hit the nail on the head as it looks
https://www.reddit.com/r/hardware/comments/j09yj5/comment/g6r7ce2
Still no explanation why some people have seen Asus cards also crashing.
Peak boost on these cards is only seen very briefly during spikes on light workloads and waaay past reference boost spec of 1710Mhz. They generally spend most of their time quite a bit lower. Like buildzoid said, "What's the problem? Most of these cards aren't boosting past 2Ghz" but then seeing even the base cards can spike very briefly to high clocks. Which would probably be enough to cause a crash. Limiting these spikes would no doubt have next to no performance repercussions. I think personally the fix is going to be fairly trivial and everyone will forget about all this. Although it seems like there could be a bunch of driver related problems thrown into the mix to confuse matters too.My theory: many cards boost past the point of stability and the fewer MLCC units the card has the quicker it passes the point of stability.
Probably we just need a new driver to fix the issue and many cards will boost to lower clocks on the new driver
Meanwhile all the reviews were done with the higher boost...Probably we just need a new driver to fix the issue and many cards will boost to lower clocks on the new driver
About the ASUS one crashing:
I think the reviewers got mixed cards, some with MLCC capacitors and some without. Might be an amateur explanation why they are reported to be crashing.
Don't need a new driver at all.
The manufacturers need to fix/replace the cards not nerf them.
As this is a NVidia screw up they really should be picking up the bill.
How is it speculation if EVGA have confirmed?
https://videocardz.com/newz/manufacturers-respond-to-geforce-rtx-3080-3090-crash-to-desktop-issues
