Rushed launch, last minute drivers, not enough time for proper testing and bug fixes. Seems like Nvidia deliberately screwed their AiB partners. #Maybe this is why certain models of the the 3080's aren't out yet, as they caught the issues there?
https://www.youtube.com/watch?v=pKi-T88jHRs&t=4m49s
I don't know the credibility of this statement, but it could mean that pre-release firmware may have fixed an issue for some partners. Then again, could be totally unrelated.
The FE has four of the cheaper caps and two of the more expensive arrays. That goes for the 3090 FE too. So clearly you don't need six.I wouldn't blame Nvida, since every card they've sold has had the 6 good quality caps on it. If Asus can do it, why can't the rest?
Alternatively, it could be that Zotac limited the card after discovering the issue in their internal testing. AIBs apparently only had a very limited amount of time to do internal testing due to Nvidia being late with drivers, so it may be that they found it late and the best they could do in the situation was a band-aid BIOS fix that lowers the boost slightly to prevent the instability from occuring (providing you never overclock it).https://www.overclockers.co.uk/foru...egards-to-the-1-3-lower-performance.18899501/
Thinking this could also be related. Could it be that the capacitor configuration is an intentional design to limit the capabilities of the GPU?
Still, at least those people are actively looking for reasoning and solutions rather than trying to set themselves up to look like the smartest guy in the room via contrarianism.People are going to look pretty stupid when this turns out to be something unrelated after being so confident they've found the cause for these 3080s crashing and going on a witchhunt over capacitors.
It sounds like some cards with the cheaper caps are actually fine at high clocks, and some of the ones with the correct config have been crashing. So no idea what is going on!
As I said in the other thread not sure this is the problem - I'm far from an expert on them but it doesn't make much sense to me - usually these capacitors are there to extend the tolerances of the GPU and it will generally work even without them - even a basic capacitor would give considerable filtering capabilities here. The symptoms of them not being upto the task would normally be more in the realm of crashing 1 in 10,000 times kind of thing. The MLCC types tend to be a bit better for filtering high frequency noise/instantaneous current demand and the tants a bit better for help with longer demands for power (though that would mostly be handled elsewhere - but the tants are more local to the demand). Then there is a whole load of ESR related stuff that I barely understand.
On a crowded PCB like Ampere I can see these capacitors being more critical but I would still expect issues related to them being insufficient or even missing to be more the order of very random and fairly rare crashes not something that is easily reproducible or someone has really screwed up on the design and you'd likely see the FE cards have some degree of symptoms of it as well.
EDIT: My guess here would be that there is a fairly big variation in individual core ASIC quality and the binning of cores for OC models is insufficient to catch the full range resulting in some with marginal stability. (Hence why some people are finding you can turn down the voltage quite a lot with little or no impact on stability and performance).
Igor suggested there is potentially two issues here.
