An AIB coming out and directly addressing and admitting the problem (and what it took to rectify the situation) is 100% cast iron proof of the situation, without any need for further speculation. Of course, there's probably still going to be some card to card variance based on the silicon lottery and manufacturing tolerances. It probably is the case that some individual cards work fine with the dodgy layout. But the issue is clearly inherent and widespread when using that capacitor layout, or there wouldn't have been such a panic about it behind the scenes and expensive, last-minute scrambling to replace it.
On the flip side the AIB chose not to follow nvidias example and cheaped out on some materials AND charge a higher price than MRSP. Wether nvidia signed off on the design or not nvidia didn't make them do this.
Yep, blaming Nvidia is a cop out. These AIB's employee a lot of engineers, so suggesting that none of those engineers could spot a simple fault in power delivery and just assumed its fine if Nvidia approved is hilarious.
The cards that are clocking over 2000MHz are they self boosting that high? I guess if ZOTAC cut their card down they are.
Yes, but what if it isn't a simple fault?Yep, blaming Nvidia is a cop out. These AIB's employee a lot of engineers, so suggesting that none of those engineers could spot a simple fault in power delivery and just assumed its fine if Nvidia approved is hilarious.
I have 25+ years experience in electronics manufacturing and I've never heard of tantalum capacitors being called 'lower quality' or 'cheaper' than multi-layer ceramic caps. They are simply different types. In cost terms multilayer ceramic caps are probably more than 25x cheaper than tantalum caps. In turn tantalum caps are larger and offer much bigger capacitance so you can put less on the board to achieve the same capacitance. The boards like the Asus TUF with all ceramics caps will likely be cheaper to build for that section even considering the extra costs for the SMT pick and place of 60 ceramic caps vs 6 tantalum caps.
They do have different characteristics like impedance, ESR etc which may account for some boards being better than others. If the capacitors do turn of to be an issue it's not going to be down to component quality or cost cutting, it's purely down to design and presumably if Nvidia have a design spec that gives the OEM board makers a choice of what to fit then the fault lies with Nvidia.
I also think NVidia already know that Ampere has a bag load of potential problems because of the way their FE cards are massively over engineered with their massive fancy coolers etc.
That looks more related to using Samsung 8nm. They had to completely blow the power budget to get the performance they wanted.
Good morning all,
I've been lurking these forums for a while now.. I'm admittedly a new convert to PC gaming and decided recently to build my first PC to get into it, predominantly (at this stage) for VR.
Anyway...
I borrowed my brothers old GPU in anticipation of the 3080 release. I pre-ordered the gigabyte eagle and it has been concerning to see the developments over the past few days regarding the issues plaguing many 3080 models.
My question:
Do you think these high end issues would affect someone like me who may not necessarily be missing out by running at factory stated Hz since I have no other high end gaming experience to benchmark from?
TIA
Jam3s
Even if you do get a faulty card the good news is this is something that will be fixed quickly and any faulty cards replaced.
I am no expert by any means, but strangely enough no one is mentioning power supply as potential casue, if the psu is pushing "dirty power" to the card could this not be the case?I'm not really convinced this is all there is to the story - I'm by no means an expert but I've enough experience to design and build a GPU power supply stage in a pinch from prototyping headphone amplifiers and know my way around things like voltage regulators and bypass caps. If you are so close to the edge of stability this is causing such a reproducible failure of this kind then something has gone very wrong.
Normally you could rip half these caps off, overclock a card to the max and maybe see sporadic instability if you were unlucky.
How are the cards faulty? They still run stable at the required base speed.Even if you do get a faulty card the good news is this is something that will be fixed quickly and any faulty cards replaced.
