Hi All
My main PC is an i7 12700k with 32 GB 5600 MHz DDR5 RAM and MSI Gaming X Trio RTX 4090. It runs any game I throw at it buttery smooth at 4K high FPS without any stutter and only minor FPS drops which are unnoticeable due to Nvidia GSync.
My bedroom PC is a i7 10700k with 32 GB 3200 MHz DDR4 RAM and MSI Ventus RTX 4090. My bedroom PC runs the same 4K games anywhere from 20 - 30 FPS slower than my main PC. This is after enabling MSI’s game boost feature CPU overlock in the motherboard BIOS of my bedroom PC. Before enabling MSI game boost I was getting 30 - 40 FPS less on my bedroom PC than my main PC.
What’s most frustrating is that sometimes when the FPS drops the bedroom PC will intermittently stutter for a micro second in all the games I tested Witcher 3 next-gen, Cyberpunk 2077 and Watch Dogs Legion. My main PC does not stutter at all. The stuttering on the bedroom PC is intermittent and doesn’t happen all the time but it’s frustrating when it does happen. The intermittent stutter and frame drops are very noticeable despite having Nvidia GSync enabled.
I’m putting this down to a CPU bottleneck with the 10700k not being able to keep up with the mighty RTX 4090 but I’m surprised if that’s the case. Everyone is always saying that CPU bottlenecks don’t occur much at 4K resolution only at 1440p or lower. It’s the reason why most tech reviewers will only benchmark games at 1080p and 1440p not 4K.
The bedroom PC is a clean install of Windows 11 and the system passes 3DMark Timespy stress tests without any issues.
I wanted to check with you all if I’m right and this is definitely due to a CPU bottleneck? I really don’t want to shell out on a new CPU and motherboard but I might need to as gaming on the 10700k system with the RTX 4090 is unplayable and takes away the enjoyment of games.
Please let me know your thoughts? Any help or advice you can give me would be greatly appreciated.
cant really compare it to what you are running when its nothing like the test
