Cool,
Got any temps compared to your stock fan?
Sorry, I don't, because I never used the stock fan.
My system idles around 32 degrees and, in the time that I have owned it, the highest temp reached has been 60 degrees.
Cool,
CheersSorry, I don't, because I never used the stock fan.
Cheers
That sounds pretty decent
The best thing is that it's virtually silent. I must actually try running the fan at full speed to see what the noise level is like.
I ran fans at full speed to check the same and its surprisingly quiet with the DRP4.
Pro 4 bit pricey, looking at dark rock 4 though, looks class
Edit: Just reading "The Dark Rock Pro 4 is significantly less convex than what we saw with the Dark Rock 4"
Time to decrease amount of common sense inhibiting drinking...Also worth pointing out not only does it turn out the esports whatever it's called cover the cores, but baseplates are primarily convex because you have a point of contact and heavy pressure in the four corners once it's attached. The idea is it gets bent slightly and provides better pressure in the middle as the pressure flattens the base. If the base starts flat then the pressure causes the flat base to become concave, which means less good contact over most of the surface area of the chip.
For reference. Here's my Dark Rock Pro 4 with TeamGroup 8-Pack RAM, Asrock X570 Taichi and a 3700X....tight squeeze!
Can I ask what temps you're getting with it?
Cryorig H7 - from what i'm reading from reddit users this is a poor choice due to its convex plate, people reporting very high temps, the convex plate is designed to draw heat away from the centre but this is less than optimal for these cpu's.
If you are willing to part with the cash, the bequiet Dark Rock Pro is a stormer of a cooler.
This was my original cooler when I got my 3700x and I agree that it's not ideal.
This is what I have installed now, temperature under full load is 60C.
Also, it's huge - practically covering my ITX board.![]()
Haven't used one yet, but the Thermalright True Spirit Power is also good. 6x8mm heatpipes. It's tall though and hard to find in some countries. If it is available, then it should cost less than Noctua and Be Quiet as well. I'm frankly surprised people don't talk about Thermalright enough.
It might have contact issues with the new ryzens though as with most high end coolers the base is slightly convex(damn you Intel). Also every cpu cooler review before this point has done on (usually) on an Intel build so it's hard to be sure how much all the old coolers actually cool the cpus.
Tested on an Intel chip, we really do need to see more tests on Ryzen 3000 chips to know if and how the non centralised layout of the chiplets affects cooling capabilities of coolers. If there is no difference then it's fine accepting results from tests like these on Intel chips but otherwise they don't have any relevance. Does anyone know if this kind of testing has been done yet by someone with access to a decent variety of coolers?Good review and comparison here between Be quiet's dark Rock and pro 4
