**RYZEN CPU COOLER INFORMATION**
Kraken ordered and proof of purchase sent.
I's just like to make you guys aware, you can only upload a single file so you will have to send both cooler and motherboard proof together as one
Actually if you go back into your ticket after you open it, you can add more files. I attached 4 in total. :)
Thu 29/10/2009, 18:05
Item: Corsair CWCH50-1 Cooling Hydro Series H50 High-performance CPU Cooler supports LGA1156 LGA775 LGA1366 AM2 and AM3 processors
Qty: 1Cost: 53.32
Wonder if Corsair will let me have an Asetek bracket for my H50, still have receipt :)
Unless the spiky ring system has changed in size/teeth count a new ring should fit an old cooler.
Cant remember where I saw the board without the brackets on but here you can see the AM3 holes peeking out from under the am4 bracket.
Cool, cheers guys. I was looking at getting the Corsair H115i and have pre-ordered the Asus Crosshair. I'll email Corsair ASAP with the proof of purchase when i do, hopefully the turnaround with the AM4 bracket is quick.
No need to contact Corsair, I also ordered the h115i but it will work out of the box.
https://www.overclock3d.net/reviews/cpu_mainboard/amd_ryzen_rog_am4_crosshair_vi_hero_preview/1
AM3/AM4 Cooler Support
One of the biggest selling points of this motherboard is its support for both AM4 and AM3 compatible coolers, with mounting holes for both CPU socket designs.
I feel like a broken record :P
I feel like a broken record :p
Would you not require an AM3 backplate though? Do the coolers come with the backplates too?
Package contents
  • Hydro Series H115i Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP140L High Torque 140mm Fans
  • USB cable for Corsair Link™ Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
Package contents
  • Quick Start Guide
Doesn't say anything about the backplate. Just has the mounting brackets.
For the ones with older Corsair AIOs with round pumps.
I found out that the H110 is not listed as compatible even with a new kit, however, the H55/75/105 are listed, and they use the same pump, and bracket as the H110.
