mi9tchy said:would this be able to work with a zalman 9500?
Jokester said:If anyone can post what cooler they're using and if it fits I'll compile a list of compatible coolers so peope can be sure.
DrSteve said:Using a DD TDX block on my IHSless core. It did just rest against the raised edge of the socket so I took some sandpaper to it. Seems to fit ok now. Just a little unsure about how much to tighten the block. Seems to be working fine at the minute though so I think I'll leave well enough alone.
Scoobie Dave said:How much, and where did you sandpaper? Im using the same waterblock and im thinking of doing this mod.
Just want to know what im letting myself in for. . .![]()
DrSteve said:The raised part that has 'socket 939' printed on it where the lever for the socket attaches. Not sure how much I took off. Just enough to make sure the chip sat higher than the socket when it was installed.
