Will doThanks please keep me updated if you dont mind really want this monitor
I gave that app a quick go but tbh had no idea what it was doing. I cycled through all of the tests and some screens were ridiculously bright. I didn't see any 'score' but the numbers in the corner showed HDR10: 1023. Do I just need to start it and leave it running for a while?
I find the window docking features built into Windows 10 to be quite poor for a screen this size. I tried using Samsung's 'Easy Setting Box' software but found it to be unreliable and it left gaps between windows. I'm currently using WinDock and can recommend it. It's very configurable and easy to use; although could be easier to configure.
With regards to HDR, I have for the moment decided to disable it in Windows as:
a) I think desktop apps look better (more consistent) without it when multi-tasking (which is most of the time)
b) having it enabled, disables the 'Eye Saver Mode' option in the monitor's settings which I will likely use far more often than HDR
it’s Tuesday and I’ve not had a dispatch notice, so presume as others have said it’s not out of stock and awaiting next batch into the warehouse. Shame as I got rid of my iMac that i was using as a separate display last Saturday. At least I’m away for a couple of days a week for the next few weeks any way so won’t miss not having a second screen that much.Shame i will to buy was i get back from holiday
If I put in an order today when will my expected ETA be?
I sent a web message to Overclockers today to ask about stock and when the next back will arrive, Not had a response yet, will post back here when I get a message back from them.
Here’s the response i’ve had, I knew i should have pre-ordered it a couple of weeks ago.
I have taken a look into the ETA for you and unfortunately we currently have not been given a date from our supplier. As soon as we receive a date we will put it online
