If you are going to run the SSDs with your old HDD's just move the pagefile to your old HDD's. Otherwise if you've got enough ram (4gb+), disable the pagefile because it'll lower the lifetime of your SSD's
ok. So what is the speed like on your desktop then? Did you get 2 or 1?
And do you think it's a good idea to turn off the pagefile m8?
Can anyone link to the most recent ATTO benchmarking program. I cannot seem to find it, even on ATTO's site! Thanks
I wish I had queried the new drive to see what its offset was set to by default
Perhaps someone else who hasn't altered their drive's offset, and whose drive was pre-formatted could do that?
Getting one next week. What do you use to query the drives existing partition offset? As looking at instruction for Diskpar it looks like it has to make the partition before giving details about it.
Follow this guide once you've installed Vista on your SSD. Should cover everything you need, if not just post here.
hahaha ok work this out right.
I've run atto once against 2 Sammys in Raid 0 using that tweaks guide shown above and i ran it again againts a Samsung F1 320GB Sata 2 HDD. The results were, well, interesting to say the least.
I've never used ATTO before less than a week ago so i don't fully understand what i am looking at yet but on the final test the results showed that in I/O Compression the F1 Spin point seemed to Muller the SSD's if what i am seeing is correct.
The Spinpoint F1 scored on the last test (1024.0) just over 150MB sec write and around 210MB sec Read. The two Samsung Solid State drives in raid 0 showed on the last test just over 100MB sec Write and just over 160MB sec Read in the same I/O compression test.
I am not sure if that is accurate though but it occurs to me that the F1 should have been completely mullered by the SSD's, it's quite suprising really. I guess that i will have to run the test again when the drives become fuller Although i do have the F1 setup in 2 partitions consisting of 160GB each and the second partition is using approximately 30GB of space.
Just ordered one of these
Hope its as good as I have read
Thanks, all ready tried all links in first 3 pages. None of them work on my pc :/ None detect any drives!
Is there a benefit to doing this then? I thought superfetch would have been better left on as it makes the most of the systems memory .
Just got myself one of these, how exactly did you do if you dont mind me askingGlad I can help . I've also moved my windows temp and IE cache folders to my raptor to save on SSD writes.
has anyone setup a RAMdisk with one of these
what did you assign to it ?
Not sure what you mean?
I will be creating a 12gb RAMdisk on my new sys (bits are here, waiting for thermal compound to arrive). I will be saving the RAMdisk image to the Samsung RAID0 array for reloading on bootup.
