Vortex, here's a slightly simpler way of achieving the same thing but without the need for searching for your profile folder, creating the js file, saving the .js file with a .txt extension despite telling Notepad user.js. Notepad by default saves files with .txt unless the user drops down the file type box in the save dialog and chooses All Files *.*. Otherwise they will get user.js.txt! To avoid that potential mishap, do the following instead
1) Open Firefox
2) Type about:config in the address bar
3) Right click any existing entry and choosing New -> String
4) Enter browser.cache.disk.parent_directory
5) Enter the full path to an existing folder on your mechanical drive for Firefox-3 to use for the disk cache. You can alt-tab away and create the folder if you haven't already created one and the alt-tab back.
6) Restart Firefox and load up a a website or two.
7) View the folder you created to ensure there are some new created cache files and folders etc. Job done!
8) If nothing appears in the folder then type about:config in the address bar again
9) In the Filter field below the tabs bar, type browser.cache and press enter. This will filter out most of the entries and show you the ones beginning with browser.cache.
10) Look for browser.cache.disk.parent_directory and then right click it and select Modify and change it accordingly. Remember to restart firefox again.
1) Open Firefox
