Don
Well the SLC version is slower, but you have less to worry about as regards write wearing and all the other issues that MLC drives suffer from.
The matrix drivers installed on mine as per the mobos instructions but 'bah' I didn't install latest. I think mine is ich9 so dirtydog do you have 2 in raid and if you do does write back cache work for you?
When I had raid running there was the error my boot driver not present or something like that. Could only boot when vista disk was in. I even went to the repair console in vista disk and startup repair. Didnt work and other probs too.
Yes Mate, see below
I have been wondering if the Nvidia storage drivers may be affecting things ?
And also, are there any settings to change in the bios ? I will take a look.
Oh, lol, someone changed my name, haaaahaaaaahaaaaahaaaa
Unless they've changed the hardware the SLC version is only about 60MB/s read.
In reality they only do about 60MB/s though.SLC is basically the same as the MLC drives spec wise (100 read 80 write). Just more pricey. They perform a little better because they don't have to do any wear levelling as they have around 10x the lifetime of the MLC drives in theory.
the SLC ones that were selling for £115 at the same place offered slightly better performance than the MLC, someone showed comparison benchmarks between them
just tried the advanced cache write back change in xp with my single drive, to be honest it doesn't really make much difference, what do you think?
With advanced cache write
Without advanced cache write
Anyone used this EWF GUI and got some feedback on it?
Going to reinstall as I ended up increasing boot time and caused some card games not to load after applying a load of registry tweaks. Gavotte Ramdisk (free) increased boot time massively, and SteadyState seemed a chore double rebooting. So just want a simple single solution for a single partitioned SSD. And even with the 512MB crash issue of EWF it looks a better option if it doesn't require multiple reboots.
