Not sure, 128K is meant to be the recommended level AFAIK. I had thought that Vista set it to that by default if you let the Vista setup format for you.
Vista defaults to a 1MB offset.
Also LeJimster, can you give me more details in regards the the cradle your using for the Samsungs, I've got an 900 case as well and that looked like a good set up for them. I know you can't provide me with a competitor, but couldn't find the product anywhere based on the description in the picture post.
my sammys under Server x64 2008, better results than i see under Vista 64 - like pretty much everything else.
HD Tach results are virtually halved now, compared to when the drive was new and empty:
SSDs in RAID totally worth it over a Velociraptor!
I'm going to try to start an install this evening of Vista 64 on them. Do I need to go through this whole thread to find the best way to carry out the install or is there a concise 1,2,3.... instructions somewhere else.
[timko];13708815 said:This...
http://www.ocztechnologyforum.com/forum/showthread.php?t=52912
...scroll down to the Vista logo section if you don't have an ICH10R based mobo
so is he suggesting you install the OS on your RAID setup, then tweak it, then install the OS again?
[timko];13704520 said:Marcsay, have you tried enabling "Advance performance" in the device manager?
It's the write usage of 10000 writes. So 128gb in raid would be 1280000 gb of writing. If you keep half spare of the disk it gives you 640000gb of writing. I'm sure on that basis it'll last a while. That calculation sounds good doesn't it - and therefore the longevity wouldn't be an issue.
Got two of these in my main machine, and TBH not that impressed. The speed is there, but i just want to 'fit and forget' and not have to worry about tweaking, movind cahes off them etc, so will be selling them on at what i paid (ie the lower price ), and going back to my raided Raptors.
Just need to build up some more posts so i can post in the FS forum now (how many posts is it these days?)
