i think this sums up the awesomeness http://www.youtube.com/watch?v=96dWOEa4Djs
I re-installed Vista fresh on my SSD's after doing the drive alignment but now the system seems to hang quite a bit, I'm running 128kb stripe and 128kb offset, is this wrong? Would this cause the freezing problems I'm having?
If I was going to change the stripe could I ghost my OS onto a spare drive then re-align the SSD's and ghost the image back or would I need a fresh install?
I'm getting about 160mbs write and 190mbs read.
Is that where it should be?
Did i see somewhere there's an indexing/defragging function I need to switch off?
How do you all post the screen prints, Ctrl-ALT-print screen doesn't seem to work for me.
[timko];13747845 said:I
Also, the high burst speed is a bug in HDTach that occurs when using that app to bench empty SSDs.
OcUK don't seem to be selling these drives... just wanted to confirm that, yes? or did they used to?
Hi Leminster,
Have received the mounting bay, one thing I forgot to ask you was how you managed to get the bay mounted into the standard grill of the Antec 900.
Did you do DIY to get it to fit into the grill or is there a third party grill available to mount it in.
I've had a look on the Overclockers site and can't find one.
Cheers again for yor assistance.
Taff
Thanks re the alt-prtscrn.
It's not empty, it has Vista 64 Ultimate on it.
I've set up a 110 gb partition for os and set aside 10 gb as scratch disc for Photoshop, anyone else does anything like this?
If you still got a regular HDD, i would recommend reclaiming the partition you've made for the scratch disk (and merge it with your system partition if possible) and just move the scratch disk to the HDD. Unless you're not bothered about the longevity of your drive.
At least, thats the way I run my system and it's still very fast.
Sorry m8, only just noticed your post.
You should have a floppy drive mounting kit with a precut hole for the 2.5 drive bay? It came with my Antec 900 at least.
