Not sure what platform these affect but I use them on both NAS and Windows so I had to update them all tonight.
If you decide to update you can find a bootable iso with the firmware at the link below:
http://tiny.cc/pw6id
How to install:
- download the file
- burn it on a CD
- boot your PC from the CD
- chooe 1) "continue to boot from FreeDos"
- chose 1) "install to harddisk using FreeDos"
- chose your desired language
- chose "run FreeDos from CD"
Now you should get the prompt x:
- type "HD204UI" and press enter
I have run into a bit of a problem. I have just installed this hdd in my system, booted up and it was showing in disk management as unallocated space. So i formatted it and allocated the space and everything went as normal and the drive was showing in windows fine.
I then followed these steps from the previous page:
How to install:
- download the file
- burn it on a CD
It seemed to work fine and said download completed. So i rebooted into windows, which took ages, really really slow boot time. When windows loaded the drive was no longer showing under my computer. So i thought i must need to reallocate in disk management, however it is not in there either :s Each time i reboot now windows takes ages to load and sits at the bios loading screen for ages :/
Edit: How very strange, decided to try the flash again only this time when selecting to boot from the cd drive the samsung hdd was not showing in the list along with the other hdd's in bios which worried me. Then when performing the last step typing "HD204UI" it kept giving me errors saying drive not found or words to that effect. I thought right that's it then, the drive is knackered, rebooted into windows which went as fast as normal and now the drive is showing![]()
I must be being thick here, I've done all of the above but when I type in HD204UI I get an error "Bad Command or Filename". DIR doesnt show this file in the directory but its certainly the image from above that I've burnt to CD. Any ideas?
*thread bump*
I've bought two of these Samsung 2TB drives and haven't used them yet so I'm in a prime position to update them.
I quick formatted them yesterday and used HD Tune to check the drives which showed they were fine.
However I noticed that they have different firmwares and one seems to have features enabled - such as temperature recording and the other doesn't...can anyone tell me what's going on and what I should do...do they both need flashing?
Side by side comparison:
I don't understand!![]()
Maybe a fault with HD Tune rather than the drives?
That's really weird isn't it!
I've read (on here I think it was) that the data corruption problem only occurs in specific circumstances which normal operation doesn't do...these are data holding drives for me so I'll be just copying stuff onto them and then reading and occasionally deleting it so I'm tempted to leave them alone and just use them as they are.
