Samsung SA 950
oh no! I thought these were 2560x1440!! I'm out
Why aren't they that's what i want to know, i really dislike all the 1920 x 1080
Oh my they are glossy, i'm a huge fan of glossy screens.
SA950 video shots on youtube make it out to a be a lovely beast...
But then its all ruined when you see Samsung babes showing a picture frame of an IPS vs PLS screen shots, and the PLS looks the business !
I must not be tempted into TN panels and must concentrate on higher quality Panels lol
The new PLS is going to be good but you are stuck with TN for sweet 120Hz still. :(
Any UK sites even have these listed? I see Speed3D does but they tend to list anything that's been announced. Holding off on the Acer 27" till I see some reviews of these.
Just had a look and its 5ms, not bad eh?
It's just a number. A fairly useless one at that. You'll have to wait for reviews from people with experience of a wide variety of different monitors panel types before you decide where the SA850 sits.
Well I look forward to the reviews, I'm guessing you'll be giving em a review PCM2? What's the link to your site?
Type in Samsung SA750 into Google and all should be revealed. Alternatively you can click on my forum name and go to the homepage. We will indeed be reviewing the SA850, SA750, SA950 and any other SA/TA series Samsungs we can get our hands on. I have been pestering Samsung endlessly about these monitors trying to make them 'crack' - but it hasn't been overly constructive so far. :p
I really hope the SA850 monitors are at least as reponsive if not more responsive than the likes of the Dell U2311H. The '5ms' suggests a good amount of grey to grey acceleration and this is something Samsung usually balance quite well without nasty visual artifacts. Unfrotunately with it being such a novel panel type it's difficult to use past examples for comparison :).
Was looking at these also, but i too am turned off by 1080 res on 27in.. and there's no way im buying a 27 tn, top to bottom viewing angle will be affected
Required
1440 res
IPS
Desired
Glass screen
120hz not so fussed
3D not so fussed
If that damn hazro would have been better I would have got onw, looks like the 2711 is still best bet
Required
1440 res
IPS
Desired
Glass screen
120hz not so fussed
3D not so fussed
Have you not read about the Samsung SA850? It won't be glass coated but will hopefully have a semi-glossy solution similar to the SA750 and SA950. You can find out more about the SA850 from various places but I recommend having a look through the first few listings on Google - http://www.google.co.uk/search?q=sa...7ADSA_en&redir_esc=&ei=mUDITaGLHdOq8QOHz7T2Bw
what's the AG type on the SA850? surely not the clear / glossy I assume al4x is asking for by listing "Glass screen" in his requirements? I expect some obvious AG/AR layers as the SA850 is being pitched as a pro monitor.
As above ^^
Many are hoping for a light anti-glare coating. Some trustworthy individuals suggest even semi glossy or similar coating to the UltraClear panel coatings used on the SA750 and SA950 series. I have never used a Samsung monitor with anti-glare coating as heavy as on recent Dell, NEC and LG IPS monitors so I think they will do quite well on that front.
That's why I asked the question again - it's unknown at this point. "Semi glossy" is too vague as a description, but I think those hoping for an Apple style clear coat are going to be disappointed.
I hope it is more as you suggest i.e. a much lighter, far less aggressive than LG style AG coat.
In the official spec sheet it was described as 'haze' which to me suggests some sort of anti-glare coating. Although people have stated it may be 'similar' to the UltraClear panel coatings I doubt anybody who has seen such a coating would describe it as 'haze'. Although it can be difficult to gauge you can see reflection of light on some of the videos that have been released (such as
) that are indicative of a 'semi-gloss' coating. I know this is a somewhat vague term and there is a bit of a spectrum there but from what I have read about and seen myself I would say the coating will deal with the most troublesome reflections without bringing the usual 'heavy AG coating' related problems to the table. The same sort of coating that is used on the BenQ EW2420.
Yeah semi AG is a little pointless. I'd rather the full glass finish tbh but if it is really light/semi glossy may be worth a look tho. I really wonder how something like that will compare to the u27. there's also the possibility that I will not like having 2 different monitors, will I miss the seemingly infinite adjustability of the dell?
Edit... it looks adjustable
'Semi AG' (a term I use loosely) isn't pointless at all and is the best solution for the majority of people (whether they realise it or not :p). It makes little sense to release a monitor designed to compete at the deep end with the U2711H if it is 'fully glossy' as common office lighting environments are not 'gloss friendly'. It is also going to have to offer a similar level of adjustability to the U2711H - full ergonomic flexibility is confirmed on the SA850. The Apple Cinema Display is a radical alternative but not a real practical competitor to the U2711H - Samsung really wants to eat away at LG's IPS panel market dominance with their PLS technology. They are accutely aware of the weaknesses of monitors using LG's panels (this includes the aggressive AG coating and poor uniformity) and are going to attempt to address these issues.
AG or glossy or semi-glossy isn't a one or the other type option. There are infinite variations possible between 100% clear and very strong AG/AR layers. Semi-glossy could be quite near to clear, or it could be quite near to the typical AG seen on office monitors. However many look similar because they are designed to comply with an ISO standard that defines just how much light should reflected (or not)
Sorry I meant AG is pointless to me for another monitor as i already have the u27 and therefore don't need another, I need at least one with it cause of the windows in the room (if I had to pick it would be AG)
