Samsung SA 950
I emailed a UK retailer and got an answer for when they should be in stock here. June, I didn't get a specific date but that does mean 1 more month to wait :(. I also asked about price point for the s27a950 and they came back with 450. So if they keep to those prices, I'm sold ^^
That seems quite closely aligned to the we have gathered here as well. If the RRP is set at around £500 with retail competition driving prices down to around £450 then I think that is excellent news. Obviously people have very high expectations of these monitors and how they actually perform remains to be seen - but they are potentially very exciting pieces of kit.
Yeah, that price seems more believable, psychas was saying 300 on page 1. I would have bought 2 for that price :D
Had my heart set on the cheaper 750, much prefer the standard pc monitor look and a lot of the features of the 950 I don't need.
It's weird, it seems the 750 is designed more for pc use and yet only the 950 has dual link dvi. Mind boggling.
As I understand it, hdmi 1.4a isn't capable of 120hz at 1080p so the only way to use that monitor with the pc at full 120hz at native res would be displayport and that's something my gpu doesn't have.
Maybe a dual link dvi to displayport adapter would work at 120hz but I can't say for sure.
So long as the input lag is low and the reviews are mostly favourable I'll be snapping one of these up.
Glossy is one of the things that put me off. I want my screen to be as non-reflective as possible. So what is the upshot of having a glossy screen? Are colours just more vibrant and less washed out?
What a perfect example of two differing viewpoints and a flimsy pretext to a recent work in progress. I and some are my colleagues are currently producing an article all about the benefits of 'matte' vs. 'glossy' screen coatings and how manufacturers are starting to respond to user dissatisfaction with the two extremes. The Samsung SA950 and SA750 series monitors are a good example of this. I am currently in discussion with Samsung about how exactly the technology is implemented but these monitors will have what is called an 'UltraClear' panel coating. This progresses away from the AR-coated glossy screens or matte coated screens of the past and is some way betwixt. They have already tested the water with this kind of coating on some of their high-end TVs and I believe they have refined it further for use on their monitors.
I didn't know that about the 750 and HDMi 1.4 not supporting 120Hz @1080p... so no 3D without displayport... :(
Does seem a very odd choice from Samsung.
I prefer the look of the 750 over the 950 too - I wonder if that stand can be changed; looks integral to the chassis.
As mentioned in our coverage, it houses the OSD navigation controls and much of the monitor electronics so there is no removing it! I also prefer the look of the 750. It is a shame they didn't add a DVI port with dual-link capability, I agree.
You can do 3d through hdmi but it will have to be either:
1080p@24hz
Or
720p@60hz
But it does confuse me to why there is no dl-dvi on a monitor... either way I do like the looks of the 950 and the price to me is pretty fair for what your getting :P
Champing at the bit here :D Howay samsung!
I was just thinking, the panel on this monitor will basically be around the same height of my current 1920x1200 24 incher won't it? Just wider but with obviously a higher pixel pitch.
If your GPU has a DisplayPort, either. If not and you want to utilise the full capabilities (including 120Hz) then the SA950.
I have wondered about one of these but I don't want 3d and don't need 120hz as I mainly play MMO's. Really not enough choices at 27", I expect the SA850 will be too expensive...
Even if you only play MMO games and have no need for 3D or 120Hz technology the SA750/SA950 can potentially offer you a lot. If you like them aesthetically that's a bonus but I am hoping they will be well built and that the UltraClear panel coating will bring a nice amount of vibrancy to the table without excessive glare or 'dulling'. The SA850 will most probably be a higher priced piece of kit but it's all speculation and who knows. Samsung might really surprise us. :p
If you mainly play MMO's I'd go for a nice ips with a high 2560 resolution.
No use making all those sacrifices when you're not going to get anything in return.
Do not get the T27A950! You must get the S27A950 version to get true 120Hz through DP/DVI-D. The screen is also not fully glossy like Apple 27". It is "semi-gloss" which is a nice compromise.
Here is crappy T input version: http://viewit.kr/401
I think the author of that article may have misinterpreted some of the information they had gathered. Whilst it is true that the monitor isn't '3D Vision Ready' (simply because it has an alternative integrated solution) that doesn't necessarily mean the monitor is incapable of utilising that system as an alternative. Here is an alternative viewpoint - some food for thought.
