Permabanned
- 29 Jul 2008
- Brisbane Australia
interesting anecdote.I had a number of SSD's fail, and I think they were all 870's. What was very suspicious about the failures was the way they failed and the fact that even when utterly broken, Samsung Magician still said they were OK.
To this day, I don't know what was wrong with them, other than they really slowed down. Eventually to a point where certain operations would never complete. Yet they checked out just fine and had a small amount of use.
This is not the first batch of Samsung drives that have done this. I, certainly, am not finding them as reliable as they are supposed to be.
i can surmise. only. that there are occasional bad batches off the assembly lines (or even just singular bad samples). whether it is the memory cells or the controllers or any of the other fiddly bits on the pcb's.
some engineers would know better.
as customers can do the warranty thing if it still applies within the warranty period.
bad samples can pass tests earlier on as they are tested prior to delivery. but end up being marginal cases i suppose, in that they pass basic testing then can fail soon after. i'm not saying anything new that i haven't heard before.
my own experiences of the least reliable parts have been motherboards. most other items I have / had typically lasted around 10 yrs or longer. ive heard anecdotes of some people still using older motherboards, and yet others that have replaced a few components and they function yet again.
I got an early crucial ssd circa 2008. 128GB it showed errors after 10 years. thing is ssd's have only been around since about then in the consumer market. and newer ones are stacking the cells increasing the density, and also running hotter. `used to be generally said that SLC was the most reliable, then MLC TLC QLC - in decreasing order of Endurance. now there is V-nand (stacked vertically)
Ushering in the era of consumer SSDs | Samsung Semiconductor Global
Welcome to part three of our in-depth series exploring landmark moments from Samsung’s history of flash memory innovation.
