anybody got any calibration settings i can use to tweak to my own taste?
Cheers mate also would like to ask is the dp cable that comes with the monitor a 1.2 or just a standard cable as I may buy one if it isn't.
DisplayPort controllers have standards, cables do not. There is no such thing as a DP 1.2 cable. The supplied cable works absolutely fine.
@ceririch
1440p does not look as nice on this display compared to a native 1440p screen. Plus input lag on this 4k monitor is the same as some 1440p ones anyway at 4k but when scaling the lag increases even more. I would stick to a really good 1440p monitor as there is no advantage with your setup for buying this monitor. Native res is always much sharper and nicer looking.
Is this true there must be differences in the cables ie like hdmi's different version cables.
Thanks mate.
Was thinking the same sort of thing, the only thing jabbing me in the back of my head is the future proofing angle.
I'll probably end up buying a 970 (or something of equivalent price) in 6 months to a years' time), so was tempted to buy this, use non native 1440p on for a few months before going 4k.
Greg, i have just got this monitor again and noticed i get stuttering when trying to play 4K videos from youtube, did you ever have this issue?
