- 24 Jan 2003
- "Are we there yet?"
How do we tell the difference and/or put it right?
Originally posted by Berserker
Are you guys sure samurize is using the .net runtime components, and not the older VB runtime components?
</edit>Originally posted by Jem
if this is correct and you've removed the offending </A> does your script now fully work? if it does can you copy and paste the changes you made on to this thread so we can all change this bit
<edit> think i found the </a> you were on about and removed it, when i ran it this came up
l version="1.0" encoding="iso-8859-1" ?>
<!DOCTYPE userstats SYSTEM "http://setiathome.ssl.berkeley.edu/xml/userstats.dtd">
<userstats>
i have no idea as to what this means but its the best its worked so far, and at least were getting somewhere</edit>
well that didnt workso its back to the drawing board so to say
Originally posted by Garp
I KNOW WHAT IT IS!
Its just suddenly struck me why the "name" parsing line has "</a>" in it on that script. Its looking for the end of an website link! My bodge involved removing that and then redoing the 'count'.
I bet those of you who have got it to work have got a website associated with your name on the SETI@home website.
I don't, hence my XML data won't have a </A> tag as part of my name!
Originally posted by si_sleaf
Weell, I've just started tinkering around with this and it is pretty good, but not without problems. I put a script in for seti and it work in the samurize config window but when I save it and reload the file it doesn't show up. It's the same with the one for my clockspeed. Any ideas where I'm going wrong?
Thank Garpworks ok now.
Just out of curiousity and to learn more about this what exactly did you change on the setionline section?
If poss could you paste the section you changed on here so we can see what & where you altered it?![]()
] This MAY cause untold problems and spurious results but as yet it is ok.
