****San Diego 3700+ Steppings and Clocks- Retail and OEM****
It's an OEM bought from OcUK on Monday. Heres a pic I took earlier tonight right after running 3dmark 2006, 40C and dropping after the benchmark :D I'm going to run prime overnight tonight to confirm it's 100% stable, I ran prime at 1750mhz with stock voltage lastnight and it was fine :)
If thats prime stable thats a very nice clock on those volts. Takes me 1.57v to get mine prime stable at that speed, so even if its not stable you've got plenty of headroom to up volts to get it there.
Hmm just looking at the speedfan tab in that pic, what cooling you using just temp 3 is at -4, and also your psu rails seem rather low???
Coolit Cheers keep me up dated with your overclock, Temps, speed , volts and speed.
Did you misstype your last post cause it says 1750?
:D will do :-) My first clock yesterday was 1750 (tested with prime), I've moved upto 2869 and will run prime tonight
Temp 3 seems to jump about a bit, I was wondering if its simply "not connected" it jumps between -6 to 24. I've confirmed the cpu temp in the bios, same with the volts (see below), Maybe the volts are read wrong by SpeedFan as I have 2x12v rails? I guess SpeedFan doesnt support my board that well :rolleyes:
core = 1.39
Vcc(3.3) = 3.4
Vcc(2.5) = 2.57
Vcc(1.5) = 1.47
Vcc(1.2) = 1.20
+12v = 11.64
Vcc(5) = 4.94
Sys Temp = 36
CPU Temp = 38
I started the test of lastnight at 12 midnight and it failed 10minutes in so I increased the core voltage by .25mv to 1mv over stalk voltages and it's rock solid.
I ran the prime torture test for 15hrs 46min and it gave me no errors and no warnings, guess I'm stable then :D
What is the highest voltage you can put through these chips on air? Can't wait to get better ram at the end of the month and go for 3ghz :eek:
You have a nice clocker Coolit, I'm quite jealous as mine wasn't even stable at 2860Mhz with 1.625V running thru it :(
What Torture test did you use?
Thanks :) you never can tell how its going to turn out so I count myself lucky ;)
I ran the default "Blend" test as I wanted a mixed system test with the ram being tested as it's maxed out. I think I'll run the "in-place large FFTs overnight tonight to stress the cooler a bit.
Any thoughts on which ram I should go for at the end of the month? I'm going to be looking for 2x1gig sticks at around £160. Tight timings or higher rated clock speed?
You guys are temping me so badly to get one of these, stop it please!! :(
How would this thing clock with a DFI Ultra D ?
Here is what I got on stock volts, can go up to HTT 260 on stock but after that its not loading windows, and I aint too bothered about messing with the cpu volts at the moment, quite happy with what I got :) This was an OEM chip from OC got it week past Friday.
