dale1uk said:You might be quite limited with that motherboard as it doesn't offer much increase in the vcore unless you mod the board itself. Saying that you've got a very nice clock there on stock volts - providing is 100% stable. I'd keep slowly upping the fsb till it becomes unstable and then up the vcore a little till its stable again, and so on alternating between the two. I'm not to sure what volts that board will allow you to put through the cpu but I've got 1.55v through mine to get it 100% stable at 2.85gig, just keep an eye on temps as the more volts the hotter things will get.
What temps are you getting under load?
