Sandy Bridge Reviews
anadtech said:
These chips overclock very well. Both my Core i5-2500K and Core i7-2600K hit ~4.4GHz, fully stable, using the stock low-profile cooler.
sweeeeet. and that stock heatsink is what, an inch tall? someone get me something bigger on one and hurry up about it!
The Sandy isn't a complete replacement of the 1156... I'm sure they'll still be around for a while yet.
It will probably take about 6 months to dump all of the old gear from the channel, I know H55 is a little cheaper than H67 at the moment and there are some backend rebates on Core i3.
Well that put pay to all that FUD that was floating around a few months ago as Sandy Bridge looks like another winner for Intel. Speaking of which I do worry for AMD as they have a huge amount of ground to make up.
Max multi is 57 for those who wonder how 5ghz is possible. 57x 103-104 is 5.928ghz so there may be the odd 6ghz chip crop up from those who are happy to push the bclk a little higher.
Issue is that at 103mhz you start to damage the likes of USB and audio.. No good really if your board loses those...
So how many of you are going for the 2500k ? i still cant decide my self really the only thing that swings me towards the 2500k is the saving of about £100.
I'm not really an overclocker so I think the i7-2600 will do. Depends on price of course, might go for one of the low-power versions if they're priced competitively.
