Colleagues,
Just arrived we have the long awaited Sapphire delivery. 5870 Vapor X, 5850 and the display port adapter are in stock and ready to ship out. All back orders will be despatched tomorrow.
Sapphire ATI Radeon HD 5870 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition. This card features Vapor Chamber Technology is based on the same principles as heatpipe technology. A liquid coolant is vaporised at a hot surface, the resulting vapor is condensed at a cold surface then the liquid is returned to the hot surface. The recirculation process is controlled by a wick system.
- Vapor-X Cooling Assembly
- Core Clock: 870MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Processing Cores: 1600
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Includes: Colin McRae DiRT
- Warranty: 2 Years
Only £329.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
- Core Clock: 725MHz
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £215.99 inc VAT.
ORDER NOW
Sapphire Active DisplayPort to Dual-Link DVI Adapter @ £79.99 inc VAT
In addition to spectacular image clarity, speed and visual effects, the Sapphire HD 5000 series supports the new multi-monitor mode known as ATI Eyefinity. This allows a single GPU to display a choice of images over an array of several monitors. The cards support up to three monitors, with a resolution of up to 7680x1600. This opens up exciting possibilities not just for multi-screen gaming, but also for information systems, multimedia systems and promotional displays.
However, with this family of cards, although two of the screens can be connected directly to the DVI or HDMI outputs on the card, the third display has to be driven from the DisplayPort output. Some users have expressed concern about the cost or availability of DisplayPort compatible monitors, or a wish to match existing monitor styles.
Sapphire has introduced an active powered DisplayPort to DVI converter, which allows any standard DVI monitor to be used as the third screen and enabled in Eyefinity mode. This allows users to update their existing multi-monitor setup to use Eyefinity, or to add a lower cost DVI monitor to complete their Eyefinity system. The SAPPHIRE converter is simply plugged into the DisplayPort output of the graphics card, together with a standard USB connection to provide power. A standard DVI monitor cable can then be connected to the female DVI connector on the unit.
Only £79.99 inc VAT.
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
ORDER NOW
