williamw11 said:Just a quick word of thanks. Used your cd image after having a lot of problems with the floppy. Worked a treat. You saved me a lot of frustration. Riva tuner shows 16 lovely pipes. Previously had a 9800se which soft modded to pro and beyond.
Havent tried o/cing it yet but am confident of xtpe speeds. Am gonna try o/cing my cpu first. Anyone using an AMD 64 3200 venice? If so what sort of overclocks are you getting.
Have
AS rock 939 dual SATA
3200 Venice
1 gig ddr 400
200 gig HDD
NEC 2510
Sapphire GTO @ x850XTPE
Generic PSU
Reckon my PSU will have to be next to bit the dust.
Cheers guys
Yes I did thankslocutus12 said:did you use the CD boot util from the forums ?
can someone tell me what coolers fit on this card please![]()
danza said:I frickin' hope my boot cd works. I burned mine with Nero 6.X, and I used my last remaining CDR!!!!!
Shidojin, what processor do you have? I'm on SKT 754, and I have ordered the Gigabyte K8NE, less than 60 quid and not toooooooo bad... Passively cooled Northbridge, so no more whiney little fans for me!!!!
