Mattus said:So which ones are quiet - the green paste ones from Singapore, or the pink paste ones from China?
Or is it not that simple?
Makes a BIG difference.sprognak said:Bench it. - And make sure you remove the jumper on the Seagate. It's only SATA-1 with it left in place.
Gommsta said:I got one of the noisy ones.
Just fitted into a Silentmaxx drive enclosure and the temperatures have dropped from 44 to 36. Noise wise its much much quieter.
Can't recommend the enclosure enough!
(running a very quiet watercooling setup)
