At least it's german and not chinese.
Amazon listing said:País de origen : China
Why would you want to swap out a 4080 for a 5080 makes no sense
F@ck, you are right... and the ******** put German flags everywhere. At least I hope it's a German design, the little documentation coming in the package is in German and the contact information points there too. Things of the globalization I guess, these days you can also buy a pretended American Tesla that could be 100% made in China (lucky me, mine was made in Berlin xDD).Sorry to disappoint you but if you look in the details it's Chinese:
The best DisplayPort cable KabelDirekt offer is DP 2.0 UHBR10.
Thanks, you seem to know what you are talking about, regarding this monitor.Sounds like cable issues to me
Make sure with the LG OLED 32GS95UE-B you are using a good HDMI 2.1 cable (Fibre one)
Don’t use DP.
Also check the monitor to set to use DSC with HDMI.
Settings > General > Input Compatibility Version is set to 2.1(PC)
This is the cable I was using:
https://www.amazon.es/gp/product/B08CRN8357
It's HDMI 2.1, has a bandwidth of 48 Gbps, and is apparently compatible with 4k@120Hz. Maybe I'm forcing it too much at 4k@240Hz, but then why the hell was it working fine with my old 4080??
I set that setting to AV and then switched back to PC, and the 240Hz were available again.It is weird that your current cable worked using your 4080.
I would try switching the input compatibility from 2.1(PC) to 2.1(AV) this will cause the monitor to go black for a few seconds and come back at 4K 120hz as DSC will be disabled.
I would then switch it back to 2.1(PC) and see if you are able to select 4K 240hz.
I would also check if you able to switch the monitor to 1080p 480hz and back and see if that does anything.
If they both fail to fix it, I would try a certified 2.1 cable that is under or 3 meters.
Awesome, so it’s working again? Do you have full 4k 240hz + sound?I set that setting to AV and then switched back to PC, and the 240Hz were available again.
At 1080p, the 480Hz was not available, unless I clicked on the physical button this monitor has to quickly switch to that mode. Then yes, I was at 1080p@480Hz.
Interesting thing though, was that when I clicked again that button to get back from that mode to 4k@240Hz, the monitor started to blink every few seconds, after a minute or so when it got stabilized.
Yes I am at 4k@240Hz but still having issues while gaming.Awesome, so it’s working again? Do you have full 4k 240hz + sound?
I think a lot of this comes down to DSC:Hi,
I'm sharing my experience with a MSI RTX 5080 Gaming Trio OC that I bought on the date of the official release. I'm seriously thinking on returning it to the retailer now that I still can for a few more days. I want to ask for advice to this community, and to see if you recommend me to do any more test before taking the final decision.
The problems begun the first day after connecting the gpu for first time and testing the first game (KCD2) at 4k@240Hz. Seconds after have started playing, I suddendly suffered a terrible image stuttering, screen blinking, followed few seconds after by a total loss of video signal, having to reboot the computer to get it back to normal.
After few research, I realized that I was using a 1.4 certified DP cable, while the RTX 5000 series is now equipped with the 2.1 version. The 1.4 theoretically only arrives to 4K@120Hz (strange I thought, because that cable was working fine with my former 4080 at 4k@240Hz). Ok, let's buy a 2.1 one then. I did it and the day after, when it arrived I tested KCD2 again and f@ck... the same issues again.
I mentioned KCD2 as example but I tested many games. I'm using a fresh Windows 11 installation. I reinstalled the drivers several times (using DDU before). I tried whatever possible configuration under the Nvidia app settings.
The only thing that works is either to decrease the resolution or the frequency of the display output:
With the DP cable, at 4k I have to set the freq to 95Hz to avoid having issues, and the same at 2k. At 1080p, I have no issues at all regardless the frequency. Another anmoying issue happening with the DP cable is that at 240Hz I get no sound from the DP output, no matter the resolution. If I set 2K or lower resolution then the sound gets back if I'm below 144Hz.
With the HDMI cable, the situation is a bit better since I always get sound through that output, but the video issues are also always happening with 4K and 120Hz or above, and with 2K at 144Hz or above. No video issues again at 1080p.
Tonight I'll do more tests with the new cable and I'll post the result. Tomorrow is my deadline for communicating the return to the retailerI think a lot of this comes down to DSC:
The RTX 5080 has DP 2.1, but your monitor only supports DP 1.4
- This means your DP connection is at 1.4, no matter what cable you use
- DP and HMDI can both use Display Stream Compression (DSC) to compress the image to fit
- Your required bandwidth at 4K, 10-bit colour, 240Hz = 68.56 Gbps
- HMDI 2.1 Bandwidth = 42.67 Gbps, so 161% usage
- DP 1.4 Bandwidth = 25.96 Gbps, so 265% usage
- Source of Bandwith calcs: https://trychen.com/feature/video-bandwidth
To your specific tries to get things working:
- DP 1.4 max refresh rate without DSC = 97 Hz (very close to the 95Hz which works)
- HDMI 2.1 max refresh rate without DSC = 155 Hz (can you try 144Hz and see if that works?)
In summary then, everything you're getting severe video issues with, you're using DSC. I haven't heard of DSC specific issues this generation, but my guess as the culprit is issues with either the ports (unlikely as multiple are affected) or the hardware on the card causing signal issues. In other words all the above calcs point to you being at the edge of what is possible via with DP and a degradation in signal could cause these issues. HDMI should be able to leverage its additional bandwidth, and we are likely seeing it do that.
Things to try next:
1) Try HDMI at 144Hz, as that should be ok
2) Try a new HDMI 2.1 cable: in theory this should be capable of 240 Hz, 4k, 10 bit colour with modest compression
3) Question: are your cable runs really long by any chance?
If 1) works, this lends a bit of weight to the idea its signal degradation interacting with DSC, if 2) works then you've got a workaround which could potentially allow you to keep your GPU until stock improves.
My conclusion though is neither DP 1.4 nor HDMI 2.1 should really have issues; unless your cable runs are long this should all be working as with your 4080, albeit with a heft dose of compression. It's therefore likely a card issue.
For what it's worth mate, I agree. Something is dodgy about the way that card is handling video outputs. An RMA is the right call.Hi. The new 2.1 HDMI cable arrived and I did some tests with it but unfortunately I get the same random monitor blinking issues, not only when playing but also when doing any other activities in Windows.
They also happen when lowering the frecuency to 144Hz.
After all the test I did with several DP and HDMI new cables on the latest standards (and knowing that my old 4080 was working fine at 4K@240H), I'm finally more inclined now to think that the root of the issue is within the graphics card (either if it's software or hardware related).
Moeover, for now there is no clear evidence of recognition from Nvidia about the issues that are happening under my specific conditions (just some communication addressed to a media where they confirm to be aware of a wide range of video issues and that they are working on a solution, so I have no clear expectation that my issues are going to be solved with the next driver.
Therefore at this point I'm afrfaid itis wiser to start the return process with the retailer and claim for a refund. I'll try to get another 5080 when it becomes available in few days or weeks, hoping that I will not get this type of issues again.
aNyway, thank you all in this community for the support you have given through this thread.
