Don't tell me that bro, cause i will cry.It'll be sods law that as soon as you send it back, a new driver will be released which has your issue amongst it's fixes
it is not a MFG. I tried games which do not support it and the issues still happen (KCD2 for instance)You mentioned something about some horiz9ntal lines you couldnt describe or are like when you wiggle the cable plugged into your TV. I had a similar problem years ago, bought a new monitor then a new gpu (not because of that but thought it would clear it up) and it never cleared it up. I was so frustrated because obviously screenshot wouldn't show it and photos on my phone wouldn't show it either but once I noticed it I couldn't unsee it. I cant remember if it was advice from a thread I posted on here or some other I fo I read but I ended up buying a proper HDMI cable (not one for the usually junk ones you get with a monitor or tv or they upsell you in PC world when buying a new tv) one from club3d and voila the problem was gone. I have not seen the issue since.
With MFG being the fakes of fake frames would they have such an affect on hardware? All I understand about MFG is it just displays a better framerate and feels awful latency wise.
I already said it. At 2k/4K and below 144Hz I don't have issues, neither at 1080p regardless the frequency.Did you limit the refresh rate in windows to 60hz, i know u dont probs want to but just to test, till a driver comes out to fix it potentially.
I suppose adaptive sync or the other vsync options in Nvidia panel dont help? Incase it might help the high refresh rate issue?
Tho if its ok at lower refresh rate and res then its usable till a fix does come along or advice from nvidia about it. So no need to rma then i guess which is good as be a pain to rma a new released card with probably low stock for awhile.
Hi, and first of all thanks for hour answer.I have only skimmed the thread so I have probably missed some key info, but…
@Markbros If this issue doesn’t appear when FPS is capped under 140fps at 4k then this is screaming at me that the problem is a ‘display stream compression’ (DSC) issue as I’ve had issues with this myself recently.
Windows and a 50 series GPU might be assuming that (as a card with a true 2.1 port) that the monitor can handle a high refresh native at 4k without DSC. However, your monitor (32GS95UE-B) cannot. Very few monitors have a 2.1 port!
There is no way in windows to disable or force display stream compression. The only way to kill the issue dead is in one direction - and that’s to disable DSC on your monitor AND have a 2.1 port on the monitor. Obviously that won’t work because your monitor can’t run 4k > 144hz without DSC.
As that’s not possible, try using 8 bit colour from the Nvidia control panel which should reduce the bandwidth… and see what happens.
For what it’s worth I have a 160hz 4k monitor and I was getting weird screen flickering… I couldn’t understand why. I swapped monitors and had no issues… but ONLY that monitor was 4K above 144hz which is the limit for 4K without DSC. Having capped the monitor at 140hz, there are no issues.
But consider that, in top of everything said in this thread, I was running 4k@240Hz with my old rtx 4080 with no issues at all!
That was using the default monitor compatibility option set to 1.4 with DSC.
I'm not an expert but that means something.
If I have to lower the freq to 144hzand wthout DSC to get rid of the issues, then what is the point of purchasing a topmonitor thst LGb bl presented a year ago as native 4k@240Hz, and a brand new card that is supposed to be designed to reach over 200fps on current and future AAA games? All this makes no sense to me.
Another anmoying issue happening with the DP cable is that at 240Hz I get no sound from the DP output, no matter the resolution. If I set 2K or lower resolution then the sound gets back if I'm below 144Hz.
I saw your setup. You also have an intel + Z790, a 4k@240Hz monitor and a RTX 5000, just like me. Very interesting. I undertand you do not suffer the video output issues playing at that monitor configuration, am I right? These are much more annoying than the fact of not getting sound from the video output.Nvidia ha confirmado hoy en los foros de GeForce que se trata de un error y que se corregirá en su próxima versión del controlador.
No estoy seguro de si el error es todo el problema que tienes, todo podría estar vinculado. Pero se está solucionando el corte de sonido cuando se usa una frecuencia de actualización alta
The sound goes back through the DP output as soon as you lower the refresh rate from 240Hz.Are you sure that your sound output isn’t automatically switching to your monitor? This can happen even if your monitor doesn’t even have speakers. Sometimes, it can actually just switch to another random peripheral. For ‘reasons’.
I can confirm I have had my PC assume that my monitor (via display port) was the speakers - as daft as that sounds.
Go into your sound settings and double check what is actually set as your output device.
The sound goes back through the DP output as soon as you lower the frequency from 240Hz.
