I'd be surprised if using a newer Pi made any difference. The web interface may be a bit quicker but a DNS resolver for a home network is unlikely to put any noticable load on a Pi.
Not noticed any slowdowns or latency on my zero w (but wired).
No difference whatsoever. In fact, my primary Pi-Hole which is providing DNS and DHCP for about 40 devices is running on an original Pi Zero (not even a W).Has anyone noticed any improvement switching to a newer pi (e.g. 2 or 3) or any real difference in speed between say a zero and a 3?
For the amount of traffic, even a 100Mb connection is perfectly adequate. My Zero runs with a £5 Ethernet adapter so the total cost for the hardware was less than a tenner.Well a 3B+ will get you much better ethernet, thought its still on USB so it's still comparably bad. Imho for an actual device where you care about networking there are much better boards out there.
I use an original day1 PI1 for my pihole. It sits there on 0% CPU most of the time, shoots up to 2-3% when there is any internet traffic. When running the admin GUI and using the pages it uses between 10-75% CPU but never goes much higher than that.
With the lists I am using I see it blocking between 15-20% of all requests and my general browsing and initial page loading sped up noticably.
Raspbian Stretch Lite.
Can't say I've had any such problem with mine, that sounds like a faulty SD card to me.
I have mine running on a RPi 3b using Stretch. Running happily alongside PiVPN(ad blocking everwhere!)I need to get mine set up again!
I've had to reinstall the OS around 3 times already. PiHole becomes inaccessible and its down to what seems like the OS getting corrupted. It won't boot, so I have to reinstall.
It is the only thing I run on the Pi, what OS do you guys use with PiHole?
Thanks @FeekGo to the web interface, Tools, Query adlists and that will show you what's blocking it.
But whitelisting it should stop that from happening. After whitelisting a domain, make sure you run pihole -g from a terminal.
/edit - Open a terminal window.
sudo nano /etc/pihole/whitelist.txt
Add these lines
4.afs.googleadservices.com
feedads.googleadservices.com
m4.afs.googleadservices.com
mimageads1.googleadservices.com
mimageads2.googleadservices.com
mimageads3.googleadservices.com
mimageads4.googleadservices.com
mimageads5.googleadservices.com
mimageads6.googleadservices.com
mimageads7.googleadservices.com
mimageads8.googleadservices.com
mimageads9.googleadservices.com
mimageads.googleadservices.com
mpartner.googleadservices.com
pagead2.googleadservices.com
www.googleadservices.com
www.partner.googleadservices.com
ctrl-x to save the file
Then type pihole -g
Yes. I did when I first set one up and my D7000 was able to power a Zero perfectly. It’ll cost you less than a tenner for a Zero W and all you’ll need is an SD card. It works perfectly well via WiFi and if you’re powering it from the router then you’ll be right next to it and can guarantee you’ll have a good signal.What's the absolute cheapest I could set up a pihole? Can you power it from a router usb port?
Jun 26 04:00:07 dnsmasq[25167]: 404852 192.168.8.169/52626 forwarded imap.gmail.com to 8.8.4.4
Jun 26 04:00:07 dnsmasq[25167]: 404851 192.168.8.169/54664 reply imap.gmail.com is <CNAME>
Jun 26 04:00:07 dnsmasq[25167]: 404851 192.168.8.169/54664 reply gmail-imap.l.google.com is 2a00:1450:400c:c06::6c
Jun 26 04:00:07 dnsmasq[25167]: 404852 192.168.8.169/52626 reply imap.gmail.com is <CNAME>
Jun 26 04:00:07 dnsmasq[25167]: 404852 192.168.8.169/52626 reply gmail-imap.l.google.com is 173.194.76.109
Jun 26 04:00:07 dnsmasq[25167]: 404852 192.168.8.169/52626 reply gmail-imap.l.google.com is 173.194.76.108
Jun 26 04:00:07 dnsmasq[25167]: 404853 192.168.8.169/52626 query[A] gmail-imap.l.google.com from 192.168.8.169
Jun 26 04:00:07 dnsmasq[25167]: 404853 192.168.8.169/52626 cached gmail-imap.l.google.com is 173.194.76.108
Jun 26 04:00:07 dnsmasq[25167]: 404853 192.168.8.169/52626 cached gmail-imap.l.google.com is 173.194.76.109
Jun 26 04:00:07 dnsmasq[25167]: read /etc/hosts - 5 addresses
Jun 26 04:00:07 dnsmasq[25167]: read /etc/pihole/lan.list - 5 addresses
Jun 26 04:00:07 dnsmasq[25167]: read /etc/pihole/local.list - 2 addresses
Jun 26 04:00:07 dnsmasq[25167]: read /etc/pihole/black.list - 0 addresses
Jun 26 04:00:09 dnsmasq[25167]: read /etc/pihole/gravity.list - 128776 addresses
Jun 26 04:00:09 dnsmasq[25167]: exiting on receipt of SIGTERM
â— dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: exit-code) since Tue 2018-06-26 07:39:25 BST; 18s ago
Process: 1502 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=1/FAILURE)
Process: 1499 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Jun 26 07:39:25 rapihole dnsmasq[1499]: dnsmasq: syntax check OK.
Jun 26 07:39:25 rapihole dnsmasq[1502]: dnsmasq: junk found in command line
Jun 26 07:39:25 rapihole dnsmasq[1502]: junk found in command line
Jun 26 07:39:25 rapihole dnsmasq[1502]: FAILED to start up
Jun 26 07:39:25 rapihole systemd[1]: dnsmasq.service: control process exited, code=exited status=1
Jun 26 07:39:25 rapihole systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 26 07:39:25 rapihole systemd[1]: Unit dnsmasq.service entered failed state.
