Setting up Pi-hole
Edit /etc/pihole/adlists.list
Add this
Code:
https://gist.githubusercontent.com/anudeepND/adac7982307fec6ee23605e281a57f1a/raw/5b8582b906a9497624c3f3187a49ebc23a9cf2fb/Test.txt
Save the file and run
Code:
pihole -g
That's a blacklist which is supposed to block Youtube ads. I can't vouch for it but it's worth a try.
That youtube ads blocklist seems to be working ok so far. Not tried it on mobile version yet though.
It's not just google, test it out on google shopping. I had to add dartsearch and all sorts, if you google an item, then try to use a referrer enabled shop link, then a lot of them are broken by pi-hole.
Same goes for HUKD links.
For now I just live with it and edit the link in the address bar.
Add this
Code:
Code:
pihole -g
Thanks Feek, i had already added that link in, although i didnt run the -g command.
Would checking the blocks on the admin GUI and unblocking the links as you browse help?
Edit, i have just tested HUKD and clicked on a good few links and i got straight through?
That link works for me. I can't click any paid links on Google though .fresh pi hole install a week ago.
I'm using standard pihole blocklist plus the youtube one posted a few days ago, and HUKD links are blocked for me too.
So when you click https://www.hotukdeals.com/deals/ht...le-dual-sim-for-21999-eglobal-central-2903199
Get Deal, that works by default for you?
On mine it's blocked via clkde.tradedoubler.com
Yes I know how to add exceptions, but it would be nice to have a HUKD and Google Shopping complete whitelist.
Yeah although i am seeing a load of ads on that site too, so i don't know if my setup isnt running as it should?
Im with Sky so i can't change DNS on the router, so im using the pi-hole as a dhcp server. Maybe this is why ours differ?
You dont seem to have your pi-hole setup or configured the same as everyone else.
Ive just tested that link and pressed the button. Firstly its blocked by the uBlock Origin addon in the browser, I allow that to go through and imediatly get the "blocked by pi-hole" window.
Yeah, it sucks that Sky block me from changing the DNS. I would say then the DHCP server fix that was posted previously doesn't fully work as well as using it for the DNS?
I would go out and pick up a better router, but don't you need a username and password on these routers with Sky?
I have an old asus r56u sitting behind my sky modem. The asus deals with the routing and points all the clients to the pi-hole for DNS and it works fine.
It should work exactly the same as long as the DHCP server is setup correctly. Can you post the output of 'ipconfig /all' from a client using the SKy router as the DHCP server then put the Pi-Hole DHCP server in place and grab the same output.
You are disabling the DHCP server on the Sky router when you enable it on Pi-Hole aren't you?
I double checked the DHCP on the Sky router again and i swear i turned off IPv6 DHCP but that was still ticked. I have turned that off now. I wonder if i was getting IP6 routing bypassing the pi-hole?
I think i may disable IPv6 all together on the router.
P.S, I can confirm, im not getting blocked messages on HUKD. :D
Anybody got any really good blocklists? I know I could use OpenDNS family guard but I want to do it myself using Pihole. I've found the Chad Mayfield list which is epic scale huge but wondered if anyone else has done this?
Personally I don't see the point in these massive blacklists. I've tried them and they cause more trouble than they're worth. The default stuff which comes with a new Pi-hole installation works perfectly well. The only ads I see are YouTube and although I found a list which blocks them (posted above somewhere), it also stopped me signing into Youtube!
I'm after more than ads. Pihole is just a very quick way of setting up a DNS server doing what I want with a nice GUI
He might want to do it for his kids, maybe? Use it more of a filtered proxy.
Spot on!
