Settings for 13700k?
14 Jul 2017
Hi I received this cpu today and I don't plan on pc for now but should I modify some settings in the bios for the sake of efficiency / thermals etc.. ?
I left everything stock for the time being but I was thinking of the load line calibration for instance
Also, is it normal that the vcore is stock above 1.3 ?
Thanks
This is the full rig
I do gaming but light video editing noting crazy
Motherboard: Asus strix z790 gaming -
Processor : Intel 13700k
GPU : RTX 4090 asus Tuf oc
Psu Seasonic Prime Ultra 1000 titaniu
Ram :gskill trident Z ddr5 6000 CL 36 2g
Watercooling : ROG Ryujin 2 360 with a12x25 fan
Case : Phanteks Eclipse P600
Case fans: a12x2
NVME : Sabrent SSD 1TB Rocket Nvm
SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500G
Screen: : LG 38GN950/ 38' / 160H
TV : LG C1 5
Mouse : asus chakram
Keyboard : asus claymore
Headset: steelserie pro wireles s2x5Zoe5ssbmdf e
fwiw this is what i've gone with so far, running on air (DH15) and i'm into gaming.
Code:
Ai Overclock Tuner [XMP II]
XMP [DDR5-6000 32-38-38-80-1.35V-1.35V]
DRAM Frequency [DDR5-6400MHz]
DRAM CAS# Latency [30]
DRAM RAS# to CAS# Delay [38]
DRAM RAS# PRE Time [38]
DRAM RAS# ACT Time [80]
DRAM Command Rate [Auto] (G2)
DRAM VDD Voltage [1.40000]
DRAM VDDQ Voltage [1.35000]
BCLK Frequency [100.0000]
ASUS MultiCore Enhancement [Disabled – Enforce All limits]
Performance Core Ratio [By Core Usage]
1-Core Ratio Limit [58]
2-Core Ratio Limit [58]
3-Core Ratio Limit [57]
4-Core Ratio Limit [57]
5-Core Ratio Limit [56]
6-Core Ratio Limit [56]
7-Core Ratio Limit [55]
8-Core Ratio Limit [55]
Global Core SVID Voltage [Adaptive Mode]
- Offset Mode Sign [-]
- Additional Turbo Mode CPU Core Voltage [Auto]
- Offset Voltage [0.03000]
CPU Load-line Calibration [Auto] (level4)
Long Duration Package Power Limit [175]
Short Duration Package Power Limit [175]
If i've not mentioned it above it is likely set to auto or i didn't think it was relevant.
Obviously zero difference in gaming performance (4k) running the above compared with leaving the power limits off and running at 6Ghz on one or two cores (can't remember exactly). It runs silent now at the desktop doing regular tasks and next to silent while gaming.
From a productivity pov, prior to the tweaks Cinebench runs would hit 100c as expected, after the tweaks it tops out at 86c without being too loud (i value a quiet PC).
Overlocked
Cinebench R23 : MC 30054 / SC 2275
Settings used above
Cinebench R23 : MC 28147 / SC 2236
Obviously the silicon lottery is the deciding factor and all this is a work in progress! Your mileage will vary ;)
Excellent. I will be building something very similar (U12A) this weekend. I’ll certainly give these setting a try.
If like me you're on air, i've gone with level 4 profile on the cpu fans and level 5 on the case fans. It stops the ramp up / down noises for short bursts of higher cpu load. My thinking is the package power limits mean i'll never get near sustained high temps so i'm not worried if i run low rpms fans most of the time.
Code:
AI Cooling [Enabled]
HYDRANODE Fan Association [Enabled]
CPU Fan Q-Fan Control [Auto Detect]
CPU Fan Profile [Standard]
CPU Fan Step Up [Level 4]
CPU Fan Step Down [Level 4]
CPU Fan Speed Low Limit [200 RPM]
Chassis Fan 1 Q-Fan Control [Auto Detect]
Chassis Fan 1 Profile [Standard]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [Level 5]
Chassis Fan 1 Step Down [Level 5]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 2 Q-Fan Control [Auto Detect]
Chassis Fan 2 Profile [Standard]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [Level 5]
Chassis Fan 2 Step Down [Level 5]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 3 Q-Fan Control [Auto Detect]
Chassis Fan 3 Profile [Standard]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Step Up [Level 5]
Chassis Fan 3 Step Down [Level 5]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 4 Q-Fan Control [Auto Detect]
Chassis Fan 4 Profile [Standard]
Chassis Fan 4 Q-Fan Source [CPU]
Chassis Fan 4 Step Up [Level 5]
Chassis Fan 4 Step Down [Level 5]
Chassis Fan 4 Speed Low Limit [200 RPM]
Chassis Fan 5 Q-Fan Control [Auto Detect]
Chassis Fan 5 Profile [Standard]
Chassis Fan 5 Q-Fan Source [CPU]
Chassis Fan 5 Step Up [Level 5]
Chassis Fan 5 Step Down [Level 5]
Chassis Fan 5 Speed Low Limit [200 RPM]
Interesting. I’ve tended to make custom PWM fan curves in the past, but have experienced occasional ramping, so I will give that a try. Thanks.
Right there with you on the custom fan curves. For now while i've been dialing in the overclock and stability i've left it to do it's thing using the above profiles. The custom fan refinement can come later :)
Good luck with your build!
Code:
Overlocked
Settings used above
Interesting!
I have not ran cb23 only 20 and it went to 86c for a sec then settled at 76c. I have to check cb23.
I have some questions
I am using a Ryujin 2 360 with a12x25 fans so I guess I can expect even better thermals?
Whats the difference between xmp 1 and 2?
About multicore enhancements, it's better to turn it off?
You left the e core stock?
What are your gaming temps?
So you let vcore on auto and just use the offset ?
Thanks again!
XMP 1 takes some settings from the RAM and the rest are provided by the motherboard. XMP 2 takes all settings from the RAM. Sometimes XMP 1 will have tighter timings if validated by the manufacturer. Sometimes they will just be the same.
MCE will attempt to boost all cores to the same level (basically an auto overclock). Good to optimise performance for heavy workloads, not good for efficiency and thermals (tends to over volt).
Oh ok thanks
i've just ran a CB23 multicore at stock settings and got those results :
i guess it's a good base right?
Also i have a weird issue
I've noticed this weird noise.
I tested and it's not a fan, not the pump.
It happens idle too.
What could it be? Coil whine of the motherboard? Is there way to fix it by some some settings?
Its really really annoying..
and what about this weird noise?
Which noise? There are a lot a lot of different noise going on in the video.
If it is the high-frequency noise then that is likely coil whine. If so, this will normally vary in tone depending on load. Could be motherboard or could be PSU if power demands have increased.
Not sure if audible.
it's not the fan or the GPu, not sure about the pump but does not feel like it (wasn't doing this on former board)
Could tweaking vcore or llc can help if it's MB coil whine?
I ran a CB23, got 30310 points.
Max temps was 91 for few seconds but it went down pretty quick and average was 76c
i gamed a bit, temps seems ok stock, maw i've seen is around 70c for now but haven't got time to play much.
Does this seem ok?
Not sure i want to go above 5400 but maybe i could use an offset too to lower temps a bit?
Also is the stock vcore normally that high? 1.376?
I've tried to lower vcore to 1.31/ llc auto and R23 passed. I know it's not the best way to test stability and I should do a prime or occt but could it be ok? I'm surprised it passed with such vdrop
Also
I have an issue that I think it's coil whine of the vrm on my board and I read that tweaking this setting can help
However I have no idea what is the stock value on auto and if I should lower it or rise it
Thanks again
Just setup my 13700K on an Asus Strix Z790 D4.
Got the dreaded coil whine issue as well.
Didn't notice it during gaming but when running Aida and watching on HWinfo64 whenever the VRM Watts ramped up so did the coil whine.
What's the best solution
Manual vcore ? Offset?
i've set manual at 1.31 + LLC4, temps are better than stock but I have no idea if i can go lower, vcore went to 1.16 during loads so i guess it's already kinda low without crashing?
