- 8 Aug 2010
- Oxfordshire
Can one of these shuttles with either sandy bridge or ivy bridge run a 2560x1600 monitor on the integrated graphics and Shuttle DVI Port?
Ideally I need to be able to use 5 sata slot's, 2 for SSD raid 0, 2 for raid 1, 1 for DVD drive.
But the shuttle only having 4 sata slot's is a bit of a head scratcher.
I plan on using the system mainly for photoshop for photo editing. Photoshop only uses the GPU for open GL, I don't think this is too intensive, so I hopefully it will work ok?
If the integrated GPU is enough then ideally I can then get a HighPoint 2720SGL for a SSD raid setup.
However if there is a way to use 5 standard sata slot's, maybe by some kind of adaptor, then I can put a nice beefy GPU in the system instead to use for casual gaming.
