My only slight concern is how noisy it might be, ive got a spare fractal 92mm fan I will probably use, and my 570 will probably get a little noisy being a twin frozr iii type in a case with little airflow, whats the psu like noise wise?
PSU noise is non existant
Fan upgrade would be worthwhile.
Can't really comment on the GPU as i don't know the cooler.
Right its arrived, and im happy with it other than the fact it is running my ram at 1333 and there is no option to change it?
That would be great, i am however only using 2 x 4gb of 1600mhz ram, i know the difference isnt great but its a little irritating all the same.
Just put my Samsungs in and all 16GB is at 1600MHz
Although SPD is CAS 11 and again I cant alter as it will do much better.
These things are tiny. The ram sticks dont even come up above the ram clips LOL
Ok update, got totally fed up and have asked for an RMA which as yet hasnt been accepted or replied to but none the less i took it to work and put it back in the office in the warehouse where its nice and cool, probably somewhere around 12-15C with out my gpu in its now nice and quiet, the fan I put in the cooler is virtually silent as it doesnt make much difference if I unplug that or not, I can still here the psu fan however but its nothing like it was at home where the ambient temp must have been around 20C or more so all I can think is when ambient temp creeps up its the cause of the noise, i didnt even put any load on the system at all but the cpu was idling mid 50's which is no good, today in the warehouse office its 37C (case off)
