Silly power requirements, an over hyped myth?
FirebarUK said:
I thought you could only run a single monitor with SLI?
I dont think the guy was actually gaming with it after I spoke to Mark, so the one screen wont of effected him, he just wanted to run 4 monitors.
fornowagain said:
That assumes the PSU has PFC, i.e. power factor = 1 (unity) otherwise the current is higher.
True, true, but with Active PFC often being 0.98-0.99 (always 0.99 with high quality PSUs) its close enough.
Plus every time I try to wrap my head around power factors, I end up more confused than when I started :p
I've put a working up there for you. But yeah, it makes no difference to the leccy bill as its only real power measured. But it does make a diffence to the fuses and wiring in the AC side of things. The reason I mention it is I think some of the US (Hiper) models don't have PFC, all EU ones should be ok.
Ah nice, thanks :) PF is meant to 'contaminate' the power isn't it? Making it harder to convert (presumably) to DC.
david25 said:
Some *crazy* numbers posted in this thread, lucky my Core Duo system only uses 57watts at idle...
Welcome to the high end :D , you want powerful hardware = high power usage.
Don't forget you can enable / disable SLI within Windows. So gaming is a single monitor (with SLI enabled), but you can quickly disable SLI and use up to 4 monitors :)
Will have to get me one of those watt monitors :eek:
I'm running my system (see sig) through a extension that vaguely measures the load & a red light comes on when hitting 3000w. Well when in 3D the red light comes on, its obviously not using 3000w with my 580w PSU but maybe the amps use equal current? any electricians here?
I dont think lower watt PSU's give enough amps not watts thats why there are 700w PSU's ? anyone???
What else do you have hooked up to the extension?
You've lost me on the amps & watts though. Amps is the number of electrons that flow through a specific point given a certain amount of time (in essence the actual current), volts is how forceful said electrons are. Think of volts as water pressure, and amps as water flow. Watts is just a single value that sums up both parts.
ok, err 19" LCD, desktop speakers, only 1 extra fan in tower.
I noticed when I got another 2 80gb drives the power went up a lot, I'll have get a monitor & find out.
Noticed my old 2x 7800gtx used more power than 1x 8800gtx.
Would this not be more aimed at the production companies? HD content encoding, number crunching etc? what is the market for it or is it just ones of thiose we did it to see if we could things?
