- 3 Nov 2004
- UK
Only censors some of them and you're not allowed to post competitor links at all.
And they're £12, I just looked.
Nullvoid said:Tom, if you're still up for running tests could you say what the peak power use is while running the power supply test that is part of s&m (some russian tool which is good for stressing components, available here: http://www.benchmarkhq.ru/be_cpu.html).
Oh and while I agree that using 1kw psu's is overkill right now, there are some benefits. One is that the psu will be running at only 40-60% of its rated output and thus its components will be far less stressed (I would worry about running a psu at 85+% of its rated output 24/7 for any great length of time). Another is that some of these new 1kw units are actually some of the most well-built ones around (I'm thinking of the thermaltake toughpower 1000w/1200w, review here: http://www.jonnyguru.com/review_details.php?id=115). Their efficiency puts other brands to shame and they remain rock-solid in terms of voltage regulation and ripple.
Yes they cost an arm and a leg, but when most of the guys using them are already splashing out oodles of cash getting sli'd 8800ultras/crossfired 2900xts, water/phase-cooling for their rig, 24+" monitors, quad-core extreme editions, I doubt they are going to be squeamish about spending in the region of £175-250 for a power supply.
AWPC said:My 8800GTX only draws 28a according to EVGA.
Trouble is SMPS phased switching PSU are often inefficient with very light loads. Most have a peak efficient point, that'll be the one they quote btw. The trick is to balance loading against the maximum point and avoid running too near the upper limit as that's not good either. The upshot of running an uber PSU with a light load is that it could well be chucking out more heat and wasting more energy than than a smaller PSU loaded correctly.Nullvoid said:Oh and while I agree that using 1kw psu's is overkill right now, there are some benefits. One is that the psu will be running at only 40-60% of its rated output and thus its components will be far less stressed (I would worry about running a psu at 85+% of its rated output 24/7 for any great length of time).
For example a Zalman ZM460-APS has a combined 12v output of 360W at 12v or 30A. And a 8800GTX at stock uses something like 130W at 12v or approx 11A.AWPC said:Running an 8800GTX on a 460Watt Zalman PSU. Its all about the amps. Mine has 34V for the combined 12V. My 8800GTX only draws 28a according to EVGA and it works perfectly.
If you have a decent PSU then the 12V figures are what you need to concern yourself with.
fornowagain said:Trouble is SMPS phased switching PSU are often inefficient with very light loads. Most have a peak efficient point, that'll be the one they quote btw. The trick is to balance loading against the maximum point and avoid running too near the upper limit as that's not good either. The upshot of running an uber PSU with a light load is that it could well be chucking out more heat and wasting more energy than than a smaller PSU loaded correctly.
The curves are an example only. Each one is different and you would need to see the efficiency curves for each PSU before you can make any decisions based on load. In that example a 200/250W load is more efficient on the 300W PSU than the 600W. Also power saving features if enabled, can put idle loads quite a way from peak values.Nullvoid said:I think if you're buying a toughpower 1kw when your system will be running at loads of between 65w-200w then you need shot![]()
fornowagain said:The curves are an example only. Each one is different and you would need to see the efficiency curves for each PSU before you can make any decisions based on load. In that example a 200/250W load is more efficient on the 300W PSU than the 600W. Also power saving features if enabled, can put idle loads quite a way from peak values.
For instance, the peak efficiency for a 1kW PSU is more likely near the 800W mark and could fall away below 450w. And a 700W psu may peak around 550W and fall away around 300W. Most are bell curves and not flat, but flatter the better and a sign of quality. My point is (other than the number/type of connections and regulation which is another issue) if you care about ongoing cost and heat. Then you should at least consider efficiency and matching PSU's to load and not just buy a big PSU for spare capacity that may never be used.
Or you could buy a Zalman ZM-MFC2 Multi Fan Controller http://www.overclockers.co.uk/showproduct.php?prodid=BB-000-ZA&groupid=701&catid=57&subcat=189TiZoR said:where did you get these meters from?
Nullvoid said:I did get your point the first time around, I just think that for some of these new breed of 1kw supplies, the only big negative is that of price. Referring back to this review you'll see the efficiency numbers are above 80% at the important 20% (well 23...), 50% and 100% loads. It does dip below 80% when it is crossloaded, but I think no modern system will have such a huge load on the 3.3v and 5v rails with next to no load on the 12v rails. As such the unit itself doesn't strictly have a peak efficiency as it is hitting the same high numbers across the majority of its range.
I think we're reaching a point where any decent modern psu will guarantee good efficiencies/voltage regulation+ripple, which leaves us with only price/modularity/power needs/warranty/noise level as the criteria when choosing which supply to buy.
This leads us to the part of the Thermaltake advertising that has tripped up most companies, efficiency. In various places the Toughpower is billed as being anywhere from 80% to 87%+ efficient. The low end of this range is almost what we would call expected in this era with power supplies as manufacturers have been pressing units through the 80 Plus program, but 87% is surpassing the numbers associated with the longtime "king" of efficient power supplies Seasonic. With this in mind we approached the Toughpower with a skeptical eye as surely this was only marketing, right? Wrong. At no point during our testing did the Toughpower even bottom out at 80%. The lowest efficiency numbers we could get out of the unit were ~82% at a 1199w load at 100v input. The unit peaked at 87.5% efficiency during the 120v testing when running a load of 609w. These numbers for a SMPS are just amazing. Until now a consumer power supply being 87% efficient was unheard of.
