- 17 Aug 2003
- Woburn Sand Dunes
Does anyone have any idea what amp module they're using inside the speakers?
i dont know the exact model but its a TDA2050 based amp with a dedicated pre.
Cheers
Would I be able to link these with a dedicated sub then? I produce dubstep as well as just listen to it, and it helps when you can hear how the bass would be reproduced through a quality sub![]()
Looks like they've disappeared of the OCUK website. Are they coming back?
I guess they can't/won't get them back in?
Less wiring mess for one. I'm quite satisfied with them, and I've owned the aegos in the past.How are they?
I have been looking at these myself (<snip>, right?) - and also at the Corsair SP2200s and the Aego M's (although the aego's are a little out of my price range).
Does anyone here know which of the three are better speakers - or if there are any better ones available for a similar price? Also what exactly is gained/lost by going 2.0 instead of 2.1?
Also, I have contacted Edifier to see if the frequency response information is available - so i'll let you know![]()
Of course like others have said in this thread, better stuff can be found second hand. But to buy new, and for simplicity these are hard to beat.
Oh, you might want to remove the link. Besides they're a lot cheaper on ocuk.![]()
How are they?
I have been looking at these myself - and also at the Corsair SP2200s and the Aego M's (although the aego's are a little out of my price range).
