Siverstone TJ 07 Build - Dark Water
Update :
CPU and NB waterloop fitted.
Clear tubing , Black Feser and Purple Primocoils.
Lots of reflections ( including cat on sofa ! ) , hence the name Dark Water.
GPU loop next.
Clear tubing , my own mix of Purple dye ( DTek Purple and Blue ) and Black Primocoils.
Cheers,
Mark
That's really good work :cool:, really neat and tidy. Aren't you just going to get dust sucked in between those dust filters though? They look like too much hassle to have to unscrew to clean...
A small update as i wait for final parts.
I never use the front connectors on a case , largely due to the miles of wiring attached which has to go to the mobo.
So i removed the front connector panel and replaced it with this :
Closed :
Open :
Temp display needed filing down about 2mm to fit , then just drill a hole in some black acrylic for the internal case light switch.
Simple, and much better than an empty gap !
Mark
Update .
Had a break ( Lost momentum and interest tbh. ) , always happens 3/4 of the way through.
Anyway , on the final straight and the finish line is in sight :D
GPU loop had to be fitted.
Distilled water and my favourite dyes ;
A bit of mixing and a colour "close" to purple :lol:
Last minute addition , a 2nd 3870 card - but didn't have a block that fitted it.
Had an idea to personalise the case , in a way that would not be permanent ( so i could sell the case on in the future )
Huge thanks go to my friend Tom here.
Acrylic panel was cut by Tom , and then i glued some AC Ryan MeshX to the back :
Then mounted 2 x 12" Purple ( well dark pink ! ) cathodes to the back :
Then just thread the wires through the case door , and onto the inverter and switch.
You can also just see a glimpse of the smoked window panel i have used in
place of the stock clear one.
Will be posting the final built pics shortly.
EDIT - Finished case pics : http://forums.overclockers.co.uk/showthread.php?t=17901084
Thanks to all that have posted in this thread , the kind words and encouragement are much appreciated. :)
Cheers,
Mark
That looks absolutely stunning. And you Sir, have some fine taste :cool:
One can really appreciate the effort that has gone into the case, it's not over the top, it's subtle and oozes quality :)
What fan controller is that out of interest?
