Siverstone TJ 07 Build - Dark Water
A small update as i wait for final parts.
I never use the front connectors on a case , largely due to the miles of wiring attached which has to go to the mobo.
So i removed the front connector panel and replaced it with this :
Closed :
Open :
Temp display needed filing down about 2mm to fit , then just drill a hole in some black acrylic for the internal case light switch.
Simple, and much better than an empty gap !
Mark
Where did you get your Fan controller from?
Oh my the gloss blackness of this case is beautiful! Makes me want to do more glossing on the interior of mine! You sir are a true inspiration to us!
Can't remember where, but it was a 'Kazemaster'
Cheers, for the comment :o
It was my first attempt at using acrylic to form an inner shell for the case.
Think it turned out OK, looking back. The basic idea has been used in quite a few builds after mine, so i would say it was a decent idea ;)
Bit of a nostalgia trip looking at Dark Water :D
Cheers,
Mark
